[SCM] PostGIS branch master updated. 3.4.0rc1-776-gf0c64c950
Thu Nov 16 22:53:37 PST 2023
the project "PostGIS".
       via  f0c64c9504156a09fc7b993ca84654d67a5e0617 (commit)
      from  86e698565bd5cf13a95fc70199f7e3d51a92c769 (commit)
revisions in full, below.
commit f0c64c9504156a09fc7b993ca84654d67a5e0617
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Nov 17 07:46:58 2023 +0100
    Adapt new functions list generator XSL to DocBook 5.0
    Use appropriate namespaces, fixing generation of the
    list_new_functions.xsl.xml which ends up being published in
    https://postgis.net/docs/manual-dev/PostGIS_Special_Functions_Index.html
    This is a follow up of acdfda8eca2c212179c16801bf07fcb3deb6f8c9
    Closes #5613
diff --git a/doc/xsl/list_new_functions.xml.xsl b/doc/xsl/list_new_functions.xml.xsl
index ef1b3c1f6..2187572eb 100644
--- a/doc/xsl/list_new_functions.xml.xsl
+++ b/doc/xsl/list_new_functions.xml.xsl
@@ -59,7 +59,7 @@
 				<xsl:variable name='tag_role' select="$tag_node/@role" />
-				<xsl:if test="$chap//para[@role=$tag_role and starts-with(./@conformance, $ver)]">
+				<xsl:if test="$chap//db:para[@role=$tag_role and starts-with(./@conformance, $ver)]">
 				<para>
 				<xsl:value-of select="substring-before($tag_para, '%')" />
@@ -71,10 +71,13 @@
 				<!-- Pull out the purpose section for each ref entry and strip whitespace and put in
 						 a variable to be tagged unto each function comment	-->
 					<xsl:for-each select="$chap//db:refentry">
 						<xsl:sort select="db:refnamediv/db:refname"/>
 						<xsl:variable name='comment'>
 							<xsl:value-of select="normalize-space(translate(translate(db:refnamediv/db:refpurpose,'&#x0d;&#x0a;', ' '), '	', ' '))"/>
 						</xsl:variable>
 						<xsl:variable name="refid">
 							<xsl:value-of select="@id" />
 						</xsl:variable>
@@ -84,8 +87,8 @@
 						</xsl:variable>
 						<!-- For each section if there is note about availability in this version -->
-						<xsl:for-each select="refsection">
-							<xsl:for-each select=".//para[@role=$tag_role and starts-with(./@conformance, $ver)]">
+						<xsl:for-each select="db:refsection">
+							<xsl:for-each select=".//db:para[@role=$tag_role and starts-with(./@conformance, $ver)]">
 								<listitem>
 									<simpara>
 										<link linkend="{$refid}"><xsl:value-of select="$refname" /></link> - <xsl:value-of select="." /><xsl:text> </xsl:text> <xsl:value-of select="$comment" />
Summary of changes:
 doc/xsl/list_new_functions.xml.xsl | 9 ++++++---
 1 file changed, 6 insertions(+), 3 deletions(-)
hooks/post-receive
