[PostGIS] #5497: Test double upgrades with locking views
PostGIS trac at osgeo.org
Thu Nov 16 23:09:56 PST 2023
  Reporter:  strk         |      Owner:  pramsey
      Type:  enhancement  |     Status:  closed
  Priority:  medium       |  Milestone:  PostGIS 3.5.0
 Component:  postgis      |    Version:  master
Resolution:  fixed        |   Keywords:
Changes (by strk):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 At the moment "locked upgrade" is always tested by `make check`, due to
 regress/runtest.mk including the use_all_functions.sql hook. This means
 `make check-double-upgrade` is already testing locked-double-upgrade and
 both Dronie and Woodie are running `make check-double-upgrade`, so I'll
 close this ticket as completed.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5497#comment:7>
