[SCM] PostGIS branch stable-3.4 updated. 3.4.0-74-gca035b901
Sun Nov 19 23:26:24 PST 2023
the project "PostGIS".
The branch, stable-3.4 has been updated
       via  ca035b9017295a7e67bd68465e90e2b3c2b84709 (commit)
       via  f248d88df3058c3fa612cdfd9196a0435fbca165 (commit)
       via  48e4e2792759b5dabd8eb63cccf00aa8d2f7513f (commit)
       via  9ee1b1bfc0f037df9321233a7f3a9d2a6d31378e (commit)
      from  7d99993edaf832f611217a4a11c28647750003dc (commit)
revisions in full, below.
commit ca035b9017295a7e67bd68465e90e2b3c2b84709
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Nov 20 02:26:14 2023 -0500
    More Prep 3.4.1
diff --git a/NEWS b/NEWS
index 5e509f53b..089f3faeb 100644
--- a/NEWS
+++ b/NEWS
@@ -42,6 +42,8 @@ To take advantage of all SFCGAL featurs, SFCGAL 1.4.1+ is needed.
  - #5603, [postgis_tiger_geocoder] Change to load 2023 Census Tiger/Line (Regina Obe)
  - #5525, [postgis_tiger_geocoder],[postgis_topology] Regression failure
           when installed by non-superuser (Regina Obe, Sandro Santilli)
+ - #5581, ST_Project(geometry, float, float) is using
+          longitudes as latitudes (Regina obe)
 * Enhancements *
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index 82c0f85e5..5dac486e5 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -47,6 +47,8 @@
                 <para><ulink url="https://trac.osgeo.org/postgis/ticket/5603">5603</ulink>, [postgis_tiger_geocoder] Change to load 2023 Census Tiger/Line (Regina Obe)</para>
                 <para><ulink url="https://trac.osgeo.org/postgis/ticket/5525">5525</ulink>, [postgis_tiger_geocoder],[postgis_topology] Regression failure
                         when installed by non-superuser (Regina Obe, Sandro Santilli)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5581">5581</ulink>, ST_Project(geometry, float, float) is using
+          longitudes as latitudes (Regina obe)</para>
              </simplesect>
             <simplesect>
commit f248d88df3058c3fa612cdfd9196a0435fbca165
Date:   Mon Nov 20 02:22:41 2023 -0500
    Remove invalid doc note on ST_SetBandPath.  Closes #5609 for PostGIS 3.4.1
diff --git a/doc/reference_raster.xml b/doc/reference_raster.xml
index ff8cd669a..be1d15b8a 100644
--- a/doc/reference_raster.xml
+++ b/doc/reference_raster.xml
@@ -7698,12 +7698,6 @@ select st_bandisnodata(rast, 1) from dummy_rast where rid = 1; -- Expected true
                     </para>
                 </note>
-                <note>
-                    <para>
-                        Internally, this method replaces the PostGIS raster's band at index <varname>band</varname> with a new band instead of updating the existing path information.
-                    </para>
-                </note>
                 <para role="availability" conformance="2.5.0">Availability: 2.5.0</para>
             </refsection>
commit 48e4e2792759b5dabd8eb63cccf00aa8d2f7513f
Date:   Mon Nov 20 02:11:03 2023 -0500
    Fix ST_Project lon,lon issue. Closes #5581 for PostGIS 3.4.1
diff --git a/liblwgeom/measures.c b/liblwgeom/measures.c
index 3469d29d7..3e255f9ec 100644
--- a/liblwgeom/measures.c
+++ b/liblwgeom/measures.c
@@ -2487,7 +2487,7 @@ project_pt(const POINT2D *P, double distance, double azimuth, POINT2D *R)
 	double dx = cos(slope) * distance;
 	double dy = sin(slope) * distance;
 	R->x = P->x + dx;
-	R->y = P->x + dy;
+	R->y = P->y + dy;
 	return LW_TRUE;
commit 9ee1b1bfc0f037df9321233a7f3a9d2a6d31378e
Date:   Mon Nov 20 01:12:23 2023 -0500
    Fix ST_LineExtend example references #5594 for PostGIS 3.4.1
diff --git a/doc/reference_editor.xml b/doc/reference_editor.xml
index b67916a71..1b6edf173 100644
--- a/doc/reference_editor.xml
+++ b/doc/reference_editor.xml
@@ -1278,9 +1278,9 @@ SELECT ST_AsText(ST_Multi('POLYGON ((10 30, 30 30, 30 10, 10 10, 10 30))'));
             <title>Example: Projected point at 100,000 meters and bearing 45 degrees </title>
 <programlisting>
-SELECT ST_AsText(ST_Project('POINT(0 0)'::geography, 100000, radians(45.0)));
+SELECT ST_AsText(ST_LineExtend('LINESTRING(0 0, 0 10)'::geometry, 5, 6));
- POINT(0.635231029125537 0.639472334729198)
+LINESTRING(0 -5,0 0,0 10,0 15)
 </programlisting>
           </refsection>
Summary of changes:
 NEWS                     | 2 ++
 doc/reference_editor.xml | 4 ++--
 doc/reference_raster.xml | 6 ------
 doc/release_notes.xml    | 2 ++
 liblwgeom/measures.c     | 2 +-
 5 files changed, 7 insertions(+), 9 deletions(-)
hooks/post-receive
