[PostGIS] #5618: Images not installing
PostGIS trac at osgeo.org
Sun Nov 19 23:51:12 PST 2023
 Reporter:  robe           |      Owner:  robe
     Type:  defect         |     Status:  new
 Priority:  blocker        |  Milestone:  PostGIS 3.5.0
Component:  documentation  |    Version:  master
 Keywords:                 |
 I suspect images aren't being installed in postgis.net.
 I say so because the new SFCGAL images I created, I see in the PDF but are
 missing on the website.
 Example case
 https://postgis.net/docs/manual-dev/en/CG_YMonotonePartition.html
 There should be an image - https://postgis.net/docs/manual-
 dev/images/cg_ymonotonepartition01.png
 and it shows in the generated PDF here -
 https://postgis.net/stuff/postgis-3.5-en.pdf
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5618>
