[PostGIS] #5618: Images not showing (was: Images not installing)
PostGIS trac at osgeo.org
Fri Nov 24 21:30:08 PST 2023
  Reporter:  robe           |      Owner:  robe
      Type:  defect         |     Status:  new
  Priority:  blocker        |  Milestone:  PostGIS 3.5.0
 Component:  documentation  |    Version:  master
Resolution:                 |   Keywords:
Changes (by robe):
 * summary:  Images not installing => Images not showing
Comment:
 on closer inspection, I see the files in the web images folder and they
 look to have same permissions as other files.
 But yet this one shows
 https://postgis.net/docs/manual-3.5/images/apple.png
 and this one doesn't show
 https://postgis.net/docs/manual-3.5/images/cg_approxconvexpartition01.png
 I'll need to check the web logs to see what's up.  I thought maybe there
 was something special about the st_ prefix, but clearly things like
 apple.png shows, though that is a static image.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5618#comment:1>
