[SCM] postgis.net branch website updated. clarity-final-77-g788c809
Fri Nov 24 20:22:02 PST 2023
the project "postgis.net".
The branch, website has been updated
       via  788c8098b470be4b21c1f3a9f9783e3150b1c73b (commit)
      from  285d1b5d7efd5246f351e23b34526d18a4c93570 (commit)
revisions in full, below.
commit 788c8098b470be4b21c1f3a9f9783e3150b1c73b
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Nov 24 23:21:54 2023 -0500
    Windows PostGIS 3.4.1 bundle
diff --git a/content/documentation/getting_started/install_windows/released_versions.md b/content/documentation/getting_started/install_windows/released_versions.md
index 37b040f..ccf194a 100644
--- a/content/documentation/getting_started/install_windows/released_versions.md
+++ b/content/documentation/getting_started/install_windows/released_versions.md
@@ -1,22 +1,22 @@
 title: Latest Released Version
-date: 2023-08-19
+date: 2023-11-24
 weight: 10
 geekdocHidden: true
 geekdocHiddenTocTree: false
-PostGIS 3.4.0 came out August 15th, 2023. Windows PostGIS Bundle 3.4.0 was released August 19th, 2023.
+PostGIS 3.4.1 came out November 20th, 2023. Windows PostGIS Bundle 3.4.1 was released November 24th, 2023.
-Binaries for versions of PostgreSQL 12-16 (64-bit) available in `Unreleased PostGIS Versions` and [OSGeo downloads][5]). Installers for 12-16(64-bit) and older releases of PostGIS are available on stackbuilder and [OSGeo downloads][5].
+Binaries for versions of PostgreSQL 12-16 (64-bit) available in `Unreleased PostGIS Versions` and [OSGeo downloads][5]). Installers for 12-16(64-bit) are available on stackbuilder and [OSGeo downloads][5].
 If you are using PostgreSQL < 12, use the PostGIS 3.3 bundle, because PostGIS 3.4+  does not support those versions.
-PostGIS 3.4.0 bundle includes:
+PostGIS 3.4.1 bundle includes:
-  * PostGIS 3.4.0 with MVT support, with raster, [GEOS](https://libgeos.org/posts/2023-06-27-geos-3-12-released/) 3.12.0, [PROJ](https://proj.org/download.html#past-releases) 8.2.1, [SFCGAL](http://sfcgal.org) support (1.4.1), address_standardizer, topology
-  * PostGIS Tiger geocoder extension - Tiger 2022
-  * pgRouting 3.5 [pgRouting 3.5.0](https://docs.pgrouting.org/3.5/en/index.html)
+  * PostGIS 3.4.1 with MVT support, with raster, [GEOS](https://libgeos.org/posts/2023-11-11-geos-3-12-1-released/) 3.12.1, [PROJ](https://proj.org/download.html#past-releases) 8.2.1, [SFCGAL](http://sfcgal.org) support (1.5.0), address_standardizer, topology
+  * PostGIS Tiger geocoder extension - Tiger 2023
+  * pgRouting 3.6 [pgRouting 3.6.0](https://docs.pgrouting.org/3.6/en/index.html)
   * Commandline raster loader (raster2pgsql), shapefile import/export (shp2pgsql,pgsql2shp)
   * Commandline [osm2pgrouting 2.3.8](https://github.com/pgRouting/osm2pgrouting/wiki/Documentation-for-osm2pgrouting-v2.3) for loading data from .osm files into pgRouting routable format
   * GUI: shp2pgsql-gui which has both import and export support for geometry/geography
@@ -29,7 +29,7 @@ PostGIS 3.4.0 bundle includes:
     for querying LIDAR point cloud and in/out functions to convert to PostGIS geometry
   * [h3-pg](https://github.com/zachasme/h3-pg) 4.1.3
     for using Uber h3 api and converting h3 index representations to postgis geometry/geography/raster (raster support is new in this release).
-  * [MobilityDB](https://mobilitydb.com) [v1.1.0alpha](https://github.com/MobilityDB/MobilityDB/releases/tag/v1.1.0-alpha)
+  * [MobilityDB](https://mobilitydb.com) [v1.1.0beta1](https://github.com/MobilityDB/MobilityDB/releases/tag/v1.1.0-beta1)
     for managing trajectories.  Includes many temporal spatial types and functions for them. Refer to [Enabling PostGIS Extensions: MobilityDb](../enabling_postgis/#mobilitydb) for guidance.
 The simplest way to get PostGIS on Windows for the EnterpriseDb Windows PostgreSQL distribution is using the StackBuilder.
Summary of changes:
 .../getting_started/install_windows/released_versions.md | 16 ++++++++--------
 1 file changed, 8 insertions(+), 8 deletions(-)
hooks/post-receive
postgis.net
