[SCM] PostGIS branch master updated. 3.4.0rc1-795-gd333bf1f6
Sat Nov 25 15:04:20 PST 2023
the project "PostGIS".
       via  d333bf1f667b35f683ef59691326d38ae711214e (commit)
      from  6db05647f6e11cfe4c1b4f2f457eb20fdc23e194 (commit)
revisions in full, below.
commit d333bf1f667b35f683ef59691326d38ae711214e
Author: Regina Obe <lr at pcorp.us>
Date:   Sat Nov 25 18:03:21 2023 -0500
    Add another example for ST_TriangulatePolygon
    that is same example as ST_Tesselate for easy compare
    Add link to ST_TriangulatePolygon from ST_Tesselate
diff --git a/doc/html/images/Makefile.in b/doc/html/images/Makefile.in
index 4232d5ba0..f34c48bab 100644
--- a/doc/html/images/Makefile.in
+++ b/doc/html/images/Makefile.in
@@ -186,6 +186,7 @@ GENERATED_IMAGES= \
 	st_polygonize01.png \
 	st_polygonize02.png \
 	st_triangulatepolygon01.png \
+	st_triangulatepolygon02.png \
 	st_segmentize01.png \
 	st_sharedpaths01.png \
 	st_sharedpaths02.png \
diff --git a/doc/html/images/wkt/st_triangulatepolygon02.wkt b/doc/html/images/wkt/st_triangulatepolygon02.wkt
new file mode 100644
index 000000000..52d248249
--- /dev/null
+++ b/doc/html/images/wkt/st_triangulatepolygon02.wkt
@@ -0,0 +1,5 @@
+Result-thin;POLYGON((50 160,120 190,120 160,50 160))
+Result-thin;POLYGON((10 70,80 130,80 70,10 70))
+Result-thin;POLYGON((50 160,10 70,10 190,50 160))
+Result-thin;POLYGON((120 190,50 160,10 190,120 190))
+Result-thin;POLYGON((80 130,10 70,50 160,80 130))
\ No newline at end of file
diff --git a/doc/reference_processing.xml b/doc/reference_processing.xml
index 796f08413..5c7f6fcc9 100644
--- a/doc/reference_processing.xml
+++ b/doc/reference_processing.xml
@@ -3036,12 +3036,50 @@ SELECT ST_AsText(
             </mediaobject>
             </informalfigure>
         </refsection>
+        <refsection><title>Same example as ST_Tesselate</title>
+            <programlisting>SELECT ST_TriangulatePolygon(
+                'POLYGON (( 10 190, 10 70, 80 70, 80 130, 50 160, 120 160, 120 190, 10 190 ))'::geometry
+                );</programlisting>
+<para>ST_AsText output</para>
+<screen>GEOMETRYCOLLECTION(POLYGON((50 160,120 190,120 160,50 160))
+    ,POLYGON((10 70,80 130,80 70,10 70))
+    ,POLYGON((50 160,10 70,10 190,50 160))
+    ,POLYGON((120 190,50 160,10 190,120 190))
+    ,POLYGON((80 130,10 70,50 160,80 130)))</screen>
+            <informaltable>
+                <tgroup cols="2">
+                <tbody>
+                      <row>
+                      <entry><para>
+                      <informalfigure>
+                        <mediaobject>
+                          <imageobject>
+                          <imagedata fileref="images/st_tesselate03.png"/>
+                          </imageobject>
+                          <caption><para>Original polygon</para></caption>
+                        </mediaobject>
+                        </informalfigure></para>
+                      </entry>
+                      <entry>
+                      <para><informalfigure>
+                        <mediaobject>
+                          <imageobject>
+                          <imagedata fileref="images/st_triangulatepolygon02.png"/>
+                          </imageobject>
+                          <caption><para>Triangulated Polygon</para></caption>
+                        </mediaobject>
+                      </entry>
+                      </row>
+                  </tbody>
+                  </tgroup>
+            </informaltable>
+        </refsection>
           <refsection>
             <title>See Also</title>
-            <para>
+            <para><xref linkend="ST_ConstrainedDelaunayTriangles"/>,
 				<xref linkend="ST_DelaunayTriangles"/>,
-				<xref linkend="ST_ConstrainedDelaunayTriangles"/>,
 				<xref linkend="ST_Tesselate"/>
             </para>
           </refsection>
diff --git a/doc/reference_sfcgal.xml b/doc/reference_sfcgal.xml
index d81db4a25..a0de2bbe0 100644
--- a/doc/reference_sfcgal.xml
+++ b/doc/reference_sfcgal.xml
@@ -1288,6 +1288,7 @@ MULTIPOLYGON(
 	  <refsection>
 		<title>Description</title>
 		<para>Takes as input a surface such a  MULTI(POLYGON) or POLYHEDRALSURFACE and returns a TIN representation via the process of tessellation using triangles.</para>
+		<note><para><xref linkend="ST_TriangulatePolygon" /> does similar to this function except that it returns a geometry collection of polygons instead of a TIN and also only works with 2D geometries.</para></note>
 		<para role="availability" conformance="2.1.0">Availability: 2.1.0</para>
 		<para>&sfcgal_required;</para>
 		<para>&Z_support;</para>
@@ -1376,7 +1377,7 @@ MULTIPOLYGON(
 		<refsection>
-                <para><xref linkend="ST_ConstrainedDelaunayTriangles"/>, <xref linkend="ST_DelaunayTriangles"/></para>
+                <para><xref linkend="ST_ConstrainedDelaunayTriangles"/>, <xref linkend="ST_DelaunayTriangles"/>, <xref linkend="ST_TriangulatePolygon"/></para>
           </refsection>
Summary of changes:
 doc/html/images/Makefile.in                     |  1 +
 doc/html/images/wkt/st_triangulatepolygon02.wkt |  5 +++
 doc/reference_processing.xml                    | 42 +++++++++++++++++++++++--
 doc/reference_sfcgal.xml                        |  3 +-
 4 files changed, 48 insertions(+), 3 deletions(-)
 create mode 100644 doc/html/images/wkt/st_triangulatepolygon02.wkt
hooks/post-receive
