[SCM] PostGIS branch master updated. 3.4.0rc1-799-gca5a819cf
Sat Nov 25 17:47:55 PST 2023
the project "PostGIS".
       via  ca5a819cfb2b79cc9aada02eb24368fd15fb690e (commit)
       via  4333c01753e3a9fcab3f4cf1d4dc0567e188cd21 (commit)
       via  1ce2a87f497e651b85cb35769dff800a286dac00 (commit)
       via  47b39be5fac33972a8afb7db8e9f1d5bf8160e94 (commit)
      from  d333bf1f667b35f683ef59691326d38ae711214e (commit)
revisions in full, below.
commit ca5a819cfb2b79cc9aada02eb24368fd15fb690e
Author: Regina Obe <lr at pcorp.us>
Date:   Sat Nov 25 20:47:46 2023 -0500
    Update pot
diff --git a/doc/po/templates/postgis-manual.pot b/doc/po/templates/postgis-manual.pot
index 511a88823..c50ccc76e 100644
--- a/doc/po/templates/postgis-manual.pot
+++ b/doc/po/templates/postgis-manual.pot
@@ -6,7 +6,7 @@ msgid ""
 msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
-"POT-Creation-Date: 2023-11-22 04:19+0000\n"
+"POT-Creation-Date: 2023-11-26 01:47+0000\n"
 "PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
 "Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
 "Language-Team: LANGUAGE <kde-i18n-doc at kde.org>\n"
@@ -14,6 +14,530 @@ msgstr ""
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
+#. Tag: chapter
+#, no-c-format
+msgid "&database_tuning;"
+msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "PostGIS Administration"
+msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "Configuring raster support"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"If you enabled raster support you may want to read below how to properly "
+"configure it."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"As of PostGIS 2.1.3, out-of-db rasters and all raster drivers are disabled "
+"by default. In order to re-enable these, you need to set the following "
+"environment variables <varname>POSTGIS_GDAL_ENABLED_DRIVERS</varname> and "
+"<varname>POSTGIS_ENABLE_OUTDB_RASTERS</varname> in the server environment. "
+"For PostGIS 2.2, you can use the more cross-platform approach of setting the "
+"corresponding <xref linkend=\"PostGIS_GUC\"/>."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "If you want to enable offline raster:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Any other setting or no setting at all will disable out of db rasters."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"In order to enable all GDAL drivers available in your GDAL install, set this "
+"environment variable as follows"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"If you want to only enable specific drivers, set your environment variable "
+"as follows:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "If you are on windows, do not quote the driver list"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Setting environment variables varies depending on OS. For PostgreSQL "
+"installed on Ubuntu or Debian via apt-postgresql, the preferred way is to "
+"edit <filename>/etc/postgresql/<replaceable>10</replaceable>/"
+"<replaceable>main</replaceable>/environment</filename> where 10 refers to "
+"version of PostgreSQL and main refers to the cluster."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"On windows, if you are running as a service, you can set via System "
+"variables which for Windows 7 you can get to by right-clicking on Computer-"
+">Properties Advanced System Settings or in explorer navigating to "
+"<varname>Control Panel\\All Control Panel Items\\System</varname>. Then "
+"clicking <emphasis>Advanced System Settings ->Advanced->Environment "
+"Variables</emphasis> and adding new system variables."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"After you set the environment variables, you'll need to restart your "
+"PostgreSQL service for the changes to take effect."
+msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "Creating spatial databases"
+msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "Spatially enable database using EXTENSION"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"If you are using PostgreSQL 9.1+ and have compiled and installed the "
+"extensions/postgis modules, you can turn a database into a spatial one using "
+"the EXTENSION mechanism."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Core postgis extension includes geometry, geography, spatial_ref_sys and all "
+"the functions and comments. Raster and topology are packaged as a separate "
+"extension."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Run the following SQL snippet in the database you want to enable spatially:"
+msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "Spatially enable database without using EXTENSION (discouraged)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"This is generally only needed if you cannot or don't want to get PostGIS "
+"installed in the PostgreSQL extension directory (for example during testing, "
+"development or in a restricted environment)."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Adding PostGIS objects and function definitions into your database is done "
+"by loading the various sql files located in <filename>[prefix]/share/"
+"contrib</filename> as specified during the build phase."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The core PostGIS objects (geometry and geography types, and their support "
+"functions) are in the <filename>postgis.sql</filename> script. Raster "
+"objects are in the <filename>rtpostgis.sql</filename> script. Topology "
+"objects are in the <filename>topology.sql</filename> script."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"For a complete set of EPSG coordinate system definition identifiers, you can "
+"also load the <filename>spatial_ref_sys.sql</filename> definitions file and "
+"populate the <varname>spatial_ref_sys</varname> table. This will permit you "
+"to perform ST_Transform() operations on geometries."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"If you wish to add comments to the PostGIS functions, you can find them in "
+"the <filename>postgis_comments.sql</filename> script. Comments can be viewed "
+"by simply typing <command>\\dd [function_name]</command> from a "
+"<command>psql</command> terminal window."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Run the following Shell commands in your terminal:"
+msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "Upgrading spatial databases"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Upgrading existing spatial databases can be tricky as it requires "
+"replacement or introduction of new PostGIS object definitions."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Unfortunately not all definitions can be easily replaced in a live database, "
+"so sometimes your best bet is a dump/reload process."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"PostGIS provides a SOFT UPGRADE procedure for minor or bugfix releases, and "
+"a HARD UPGRADE procedure for major releases."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Before attempting to upgrade PostGIS, it is always worth to backup your "
+"data. If you use the -Fc flag to pg_dump you will always be able to restore "
+"the dump with a HARD UPGRADE."
+msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "Soft upgrade"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"If you installed your database using extensions, you'll need to upgrade "
+"using the extension model as well. If you installed using the old sql script "
+"way, you are advised to switch your install to extensions because the script "
+"way is no longer supported."
+msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "Soft Upgrade 9.1+ using extensions"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"If you originally installed PostGIS with extensions, then you need to "
+"upgrade using extensions as well. Doing a minor upgrade with extensions, is "
+"fairly painless."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"If you are running PostGIS 3 or above, then you should use the <xref "
+"linkend=\"PostGIS_Extensions_Upgrade\"/> function to upgrade to the latest "
+"version you have installed."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "If you are running PostGIS 2.5 or lower, then do the following:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"If you have multiple versions of PostGIS installed, and you don't want to "
+"upgrade to the latest, you can explicitly specify the version as follows:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "If you get an error notice something like:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Then you'll need to backup your database, create a fresh one as described in "
+"<xref linkend=\"create_new_db_extensions\"/> and then restore your backup on "
+"top of this new database."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "If you get a notice message like:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Then everything is already up to date and you can safely ignore it. "
+"<emphasis role=\"bold\">UNLESS</emphasis> you're attempting to upgrade from "
+"an development version to the next (which doesn't get a new version number); "
+"in that case you can append \"next\" to the version string, and next time "
+"you'll need to drop the \"next\" suffix again:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"If you installed PostGIS originally without a version specified, you can "
+"often skip the reinstallation of postgis extension before restoring since "
+"the backup just has <code>CREATE EXTENSION postgis</code> and thus picks up "
+"the newest latest version during restore."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"If you are upgrading PostGIS extension from a version prior to 3.0.0, you "
+"will have a new extension <emphasis>postgis_raster</emphasis> which you can "
+"safely drop, if you don't need raster support. You can drop as follows:"
+msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "Soft Upgrade Pre 9.1+ or without extensions"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"This section applies only to those who installed PostGIS not using "
+"extensions. If you have extensions and try to upgrade with this approach "
+"you'll get messages like:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"NOTE: if you are moving from PostGIS 1.* to PostGIS 2.* or from PostGIS 2.* "
+"prior to r7409, you cannot use this procedure but would rather need to do a "
+"<link linkend=\"hard_upgrade\">HARD UPGRADE</link>."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"After compiling and installing (make install) you should find a set of "
+"<filename>*_upgrade.sql</filename> files in the installation folders. You "
+"can list them all with:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Load them all in turn, starting from <filename>postgis_upgrade.sql</"
+"filename>."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The same procedure applies to raster, topology and sfcgal extensions, with "
+"upgrade files named <filename>rtpostgis_upgrade.sql</filename>, "
+"<filename>topology_upgrade.sql</filename> and <filename>sfcgal_upgrade.sql</"
+"filename> respectively. If you need them:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "You are advised to switch to an extension based install by running"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"If you can't find the <filename>postgis_upgrade.sql</filename> specific for "
+"upgrading your version you are using a version too early for a soft upgrade "
+"and need to do a <link linkend=\"hard_upgrade\">HARD UPGRADE</link>."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The <xref linkend=\"PostGIS_Full_Version\"/> function should inform you "
+"about the need to run this kind of upgrade using a \"procs need upgrade\" "
+"message."
+msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "Hard upgrade"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"By HARD UPGRADE we mean full dump/reload of postgis-enabled databases. You "
+"need a HARD UPGRADE when PostGIS objects' internal storage changes or when "
+"SOFT UPGRADE is not possible. The <link linkend=\"release_notes\">Release "
+"Notes</link> appendix reports for each version whether you need a dump/"
+"reload (HARD UPGRADE) to upgrade."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The dump/reload process is assisted by the postgis_restore script which "
+"takes care of skipping from the dump all definitions which belong to PostGIS "
+"(including old ones), allowing you to restore your schemas and data into a "
+"database with PostGIS installed without getting duplicate symbol errors or "
+"bringing forward deprecated objects."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Supplementary instructions for windows users are available at <link xlink:"
+"href=\"http://trac.osgeo.org/postgis/wiki/UsersWikiWinUpgrade\">Windows Hard "
+"upgrade</link>."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "The Procedure is as follows:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Create a \"custom-format\" dump of the database you want to upgrade (let's "
+"call it <varname>olddb</varname>) include binary blobs (-b) and verbose (-v) "
+"output. The user can be the owner of the db, need not be postgres super "
+"account."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Do a fresh install of PostGIS in a new database -- we'll refer to this "
+"database as <varname>newdb</varname>. Please refer to <xref "
+"linkend=\"create_new_db\"/> and <xref linkend=\"create_new_db_extensions\"/> "
+"for instructions on how to do this."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The spatial_ref_sys entries found in your dump will be restored, but they "
+"will not override existing ones in spatial_ref_sys. This is to ensure that "
+"fixes in the official set will be properly propagated to restored databases. "
+"If for any reason you really want your own overrides of standard entries "
+"just don't load the spatial_ref_sys.sql file when creating the new db."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"If your database is really old or you know you've been using long deprecated "
+"functions in your views and functions, you might need to load "
+"<filename>legacy.sql</filename> for all your functions and views etc. to "
+"properly come back. Only do this if _really_ needed. Consider upgrading your "
+"views and functions before dumping instead, if possible. The deprecated "
+"functions can be later removed by loading <filename>uninstall_legacy.sql</"
+"filename>."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Restore your backup into your fresh <varname>newdb</varname> database using "
+"postgis_restore. Unexpected errors, if any, will be printed to the standard "
+"error stream by psql. Keep a log of those."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Errors may arise in the following cases:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Some of your views or functions make use of deprecated PostGIS objects. In "
+"order to fix this you may try loading <filename>legacy.sql</filename> script "
+"prior to restore or you'll have to restore to a version of PostGIS which "
+"still contains those objects and try a migration again after porting your "
+"code. If the <filename>legacy.sql</filename> way works for you, don't forget "
+"to fix your code to stop using deprecated functions and drop them loading "
+"<filename>uninstall_legacy.sql</filename>."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Some custom records of spatial_ref_sys in dump file have an invalid SRID "
+"value. Valid SRID values are bigger than 0 and smaller than 999000. Values "
+"in the 999000.999999 range are reserved for internal use while values > "
+"999999 can't be used at all. All your custom records with invalid SRIDs will "
+"be retained, with those > 999999 moved into the reserved range, but the "
+"spatial_ref_sys table would lose a check constraint guarding for that "
+"invariant to hold and possibly also its primary key ( when multiple invalid "
+"SRIDS get converted to the same reserved SRID value )."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"In order to fix this you should copy your custom SRS to a SRID with a valid "
+"value (maybe in the 910000..910999 range), convert all your tables to the "
+"new srid (see <xref linkend=\"UpdateGeometrySRID\"/>), delete the invalid "
+"entry from spatial_ref_sys and re-construct the check(s) with:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"If you are upgrading an old database containing french <link xlink:"
+"href=\"https://en.wikipedia.org/wiki/Institut_g%C3%A9ographique_national\"> "
+"IGN </link> cartography, you will have probably SRIDs out of range and you "
+"will see, when importing your database, issues like this :"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"In this case, you can try following steps : first throw out completely the "
+"IGN from the sql which is resulting from postgis_restore. So, after having "
+"run :"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "run this command :"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Create then your newdb, activate the required Postgis extensions, and insert "
+"properly the french system IGN with : <link xlink:href=\"https://raw."
+"githubusercontent.com/Remi-C/IGN_spatial_ref_for_PostGIS/master/"
+"Put_IGN_SRS_into_Postgis.sql\"> this script </link> After these operations, "
+"import your data :"
+msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Performance Tuning"
@@ -12862,7 +13386,7 @@ msgstr ""
 #. Tag: title
 #, no-c-format
-msgid "Example: Projected point at 100,000 meters and bearing 45 degrees"
+msgid "Example: Extends a line 5 units forward and 6 units backward"
 msgstr ""
 #. Tag: para
@@ -12965,6 +13489,11 @@ msgid ""
 "Enhanced: 3.4.0 Allow geometry arguments and two-point form omitting azimuth."
 msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "Example: Projected point at 100,000 meters and bearing 45 degrees"
+msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -21890,11 +22419,30 @@ msgstr ""
 msgid "Polygon Triangulation"
 msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "Same example as ST_Tesselate"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "ST_AsText output"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Original polygon"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Triangulated Polygon"
+msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-", <xref linkend=\"ST_ConstrainedDelaunayTriangles\"/>, <xref "
-"linkend=\"ST_Tesselate\"/>"
+", <xref linkend=\"ST_DelaunayTriangles\"/>, <xref linkend=\"ST_Tesselate\"/>"
 msgstr ""
 #. Tag: refpurpose
@@ -31039,11 +31587,6 @@ msgstr ""
 msgid "Compute a straight skeleton from a geometry"
 msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Original polygon"
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid "Straight Skeleton of polygon"
@@ -31063,6 +31606,13 @@ msgid ""
 "returns a TIN representation via the process of tessellation using triangles."
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"does similar to this function except that it returns a geometry collection "
+"of polygons instead of a TIN and also only works with 2D geometries."
+msgstr ""
 #. Tag: para
 #, no-c-format
 msgid "Original Cube"
@@ -31078,11 +31628,6 @@ msgstr ""
 msgid "Tesselated Cube with triangles colored"
 msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "ST_AsText output"
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid "Tesselated Polygon"
@@ -31090,7 +31635,9 @@ msgstr ""
 #. Tag: para
 #, no-c-format
-msgid ", <xref linkend=\"ST_DelaunayTriangles\"/>"
+msgid ""
+", <xref linkend=\"ST_DelaunayTriangles\"/>, <xref "
+"linkend=\"ST_TriangulatePolygon\"/>"
 msgstr ""
 #. Tag: refpurpose
commit 4333c01753e3a9fcab3f4cf1d4dc0567e188cd21
Date:   Sat Nov 25 20:43:27 2023 -0500
    Fix what's new and what's changed in this release
    in cheatsheets.  Closes #5620 for PostGIS 3.5.0dev
diff --git a/doc/xsl/common_cheatsheet.xsl b/doc/xsl/common_cheatsheet.xsl
index 64d85b474..1645cec5d 100644
--- a/doc/xsl/common_cheatsheet.xsl
+++ b/doc/xsl/common_cheatsheet.xsl
@@ -107,10 +107,10 @@
 					<xsl:value-of select="db:refnamediv/db:refname" />
 				</a>
 			</span>
-		<xsl:if test="$ref//para[@role=$new_tag and starts-with(./@conformance, $postgis_version)]">
+		<xsl:if test="$ref//db:para[@role=$new_tag and starts-with(@conformance, $postgis_version)]">
 			 <sup>1</sup>
 		</xsl:if>
-		<xsl:if test="$ref//para[@role=$enhanced_tag and starts-with(./@conformance, $postgis_version)]">
+		<xsl:if test="$ref//db:para[@role=$enhanced_tag and starts-with(@conformance, $postgis_version)]">
 			 <sup>2</sup>
 		</xsl:if>
 		<xsl:if test="$ref/descendant::*[@conformance=$sqlmm_conformance_tag]">
commit 1ce2a87f497e651b85cb35769dff800a286dac00
Date:   Sat Nov 25 20:43:20 2023 -0500
    Get rid of useless chapter reference in sfcgal cheatsheet.  It's a section not a chapter
diff --git a/doc/xsl/sfcgal_cheatsheet.html.xsl b/doc/xsl/sfcgal_cheatsheet.html.xsl
index bb891878b..701970051 100644
--- a/doc/xsl/sfcgal_cheatsheet.html.xsl
+++ b/doc/xsl/sfcgal_cheatsheet.html.xsl
@@ -18,8 +18,6 @@
 	<xsl:include href="common_utils.xsl" />
 	<xsl:include href="common_cheatsheet.xsl" />
-  <xsl:variable name="chapter_id" select='"RT_reference"' />
 	<xsl:output method="html" />
 <xsl:template match="/">
commit 47b39be5fac33972a8afb7db8e9f1d5bf8160e94
Date:   Sat Nov 25 20:10:04 2023 -0500
    Fix ST_LineExtend example
    closes #5594 for PostGIS 3.5.0dev
diff --git a/doc/reference_editor.xml b/doc/reference_editor.xml
index 6f524ec14..1d03a94e0 100644
--- a/doc/reference_editor.xml
+++ b/doc/reference_editor.xml
@@ -1275,7 +1275,7 @@ SELECT ST_AsText(ST_Multi('POLYGON ((10 30, 30 30, 30 10, 10 10, 10 30))'));
           </refsection>
           <refsection>
-            <title>Example: Projected point at 100,000 meters and bearing 45 degrees </title>
+            <title>Example: Extends a line 5 units forward and 6 units backward</title>
 <programlisting>
 SELECT ST_AsText(ST_LineExtend('LINESTRING(0 0, 0 10)'::geometry, 5, 6));
Summary of changes:
 doc/po/templates/postgis-manual.pot | 575 +++++++++++++++++++++++++++++++++++-
 doc/reference_editor.xml            |   2 +-
 doc/xsl/common_cheatsheet.xsl       |   4 +-
 doc/xsl/sfcgal_cheatsheet.html.xsl  |   2 -
 4 files changed, 564 insertions(+), 19 deletions(-)
hooks/post-receive
