[PostGIS] #5621: LINESTRING EMPTY crashes nested ST_PointOnSurface and ST_Collect
PostGIS trac at osgeo.org
Sat Nov 25 19:53:24 PST 2023
 Reporter:  Wenjing   |      Owner:  pramsey
     Type:  defect    |     Status:  new
 Priority:  critical  |  Milestone:  PostGIS 3.4.2
Component:  postgis   |    Version:  3.4.x
 Keywords:            |
 LINESTRING EMPTY crashes nested ST_PointOnSurface and ST_Collect. I found
 and reported the same issue also in DuckDB:
 https://github.com/duckdb/duckdb_spatial/issues/195
 SELECT ST_PointOnSurface(ST_Collect([ST_GeomFromText('LINESTRING(0 0, 1
 1)'), ST_GeomFromText('LINESTRING EMPTY')]))
 --Segmentation fault (core dumped)
 Here is the stack information:
 #0  0x00007f05988a9848 in
 geos::algorithm::InteriorPointLine::add(geos::geom::Coordinate const&) ()
    from /usr/local/lib/libgeos.so.3.13.0
 #1  0x00007f05988a993d in
 geos::algorithm::InteriorPointLine::addInterior(geos::geom::CoordinateSequence
 const*) ()
 #2  0x00007f05988a99d8 in
 geos::algorithm::InteriorPointLine::addInterior(geos::geom::Geometry
 const*) ()
 #3  0x00007f05988a9beb in
 geos::algorithm::InteriorPointLine::InteriorPointLine(geos::geom::Geometry
 const*) ()
 #4  0x00007f05989044b5 in geos::geom::Geometry::getInteriorPoint() const
 #5  0x00007f05990808af in GEOSPointOnSurface_r ()
    from /usr/local/lib/libgeos_c.so.1
 #6  0x00007f05993d8649 in lwgeom_pointonsurface (geom=0x560078958718)
     at lwgeom_geos.c:1025
 #7  0x00007f059930ab5c in pointonsurface (fcinfo=0x56007895ca10)
     at lwgeom_geos.c:1496
 #8  0x000056007653aed0 in ExecInterpExpr ()
 #9  0x000056007662a4a4 in evaluate_expr ()
 #10 0x000056007662a6f1 in simplify_function ()
 #11 0x000056007662b68d in eval_const_expressions_mutator ()
 #12 0x00005600765a6881 in expression_tree_mutator_impl ()
 #13 0x00005600765a6d5c in expression_tree_mutator_impl ()
 #14 0x000056007662c5e3 in eval_const_expressions ()
 #15 0x0000560076612418 in preprocess_expression ()
 #16 0x0000560076619832 in subquery_planner ()
 #17 0x000056007661a023 in standard_planner ()
 #18 0x00005600766d721f in pg_plan_query ()
 #19 0x00005600766d7301 in pg_plan_queries ()
 #20 0x00005600766d75e0 in exec_simple_query ()
 #21 0x00005600766d9a05 in PostgresMain ()
 #22 0x0000560076653bce in ServerLoop ()
 #23 0x0000560076654b1c in PostmasterMain ()
 #24 0x00005600763a6bb1 in main ()
 Version:
                 postgis_full_version
  POSTGIS="3.5.0dev 3.4.0rc1-800-g96e265b7a" [EXTENSION] PGSQL="170"
 GEOS="3.13.0dev-CAPI-1.18.0" PROJ="8.2.1 NETWORK_ENABLED=OFF
 URL_ENDPOINT=https://cdn.proj.org USER_WRITABLE_DIRECTORY=/tmp/proj
 DATABASE_PATH=/usr/share/proj/proj.db" LIBXML="2.9.13"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5621>
