[SCM] PostGIS branch master updated. 3.4.0rc1-808-ga6f4fa828
Tue Nov 28 00:15:28 PST 2023
the project "PostGIS".
       via  a6f4fa8282d3fef7e298f66cb7db96674486f028 (commit)
      from  75a4fb5656d537b06c2cfe61458f9ecace675150 (commit)
revisions in full, below.
commit a6f4fa8282d3fef7e298f66cb7db96674486f028
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Nov 28 09:11:30 2023 +0100
    Fix hard-upgrades failing to skip old st_asgeojson signature
    Uses "Replaces" comment instead of _postgis_drop_function_by_identity
    function. The latter is only required when the function signature
    remains the same but argument names change. These cases are of no
    interest for postgis_restore because only the signature (and not the
    identity) can be found in PostgreSQL dumps, and so we didn't bother
    to implement support for _postgis_drop_function_by_identity in the
    script that extracts the skip-list for postgis_restore.
    Closes #5623
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 80eba72c5..69cbb00d5 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -5054,6 +5054,7 @@ CREATE OR REPLACE FUNCTION ST_AsGeoJson(geom geometry, maxdecimaldigits integer
 -- Availability: 3.0.0
 -- Changed: 3.5.0 add id_column='' parameter
+-- Replaces ST_AsGeoJson(record, text, integer, bool) deprecated in 3.5.0
 CREATE OR REPLACE FUNCTION ST_AsGeoJson(r record, geom_column text DEFAULT '', maxdecimaldigits integer DEFAULT 9, pretty_bool boolean DEFAULT false, id_column text DEFAULT '')
 	RETURNS text
 	AS 'MODULE_PATHNAME','ST_AsGeoJsonRow'
diff --git a/postgis/postgis_before_upgrade.sql b/postgis/postgis_before_upgrade.sql
index 56484b1af..206969f40 100644
--- a/postgis/postgis_before_upgrade.sql
+++ b/postgis/postgis_before_upgrade.sql
@@ -172,10 +172,3 @@ BEGIN
 		END IF;
 END;
--- FUNCTION ST_AsGeoJson added `id_column` optional argument in 3.5.0.
-SELECT _postgis_drop_function_by_identity
-	'ST_AsGeoJson',
-	'r record, geom_column text, maxdecimaldigits integer, pretty_bool boolean'
Summary of changes:
 postgis/postgis.sql.in             | 1 +
 postgis/postgis_before_upgrade.sql | 7 -------
 2 files changed, 1 insertion(+), 7 deletions(-)
hooks/post-receive
