[SCM] PostGIS branch master updated. 3.4.0rc1-809-ge688a7d3d
Tue Nov 28 04:24:01 PST 2023
the project "PostGIS".
       via  e688a7d3dad379a5928d3404545628ac588837b0 (commit)
      from  a6f4fa8282d3fef7e298f66cb7db96674486f028 (commit)
revisions in full, below.
commit e688a7d3dad379a5928d3404545628ac588837b0
Author: Zuochenwei <zuochenwei5 at gmail.com>
Date:   Tue Nov 28 11:17:31 2023 +0000
    Translated PostGIS Manual using Weblate (Chinese (Simplified))
    Currently translated at 100.0% (5645 of 5645 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/zh_Hans/
diff --git a/doc/po/zh_Hans/postgis-manual.po b/doc/po/zh_Hans/postgis-manual.po
index c6f97a578..5a8f905b0 100644
--- a/doc/po/zh_Hans/postgis-manual.po
+++ b/doc/po/zh_Hans/postgis-manual.po
@@ -6,7 +6,7 @@ msgstr ""
 "Project-Id-Version: postgis 3.5\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2023-11-26 01:47+0000\n"
-"PO-Revision-Date: 2023-11-16 06:23+0000\n"
+"PO-Revision-Date: 2023-11-28 12:23+0000\n"
 "Last-Translator: Zuochenwei <zuochenwei5 at gmail.com>\n"
 "Language-Team: Chinese (Simplified) <https://weblate.osgeo.org/projects/"
 "postgis/postgis-manual/zh_Hans/>\n"
@@ -9023,6 +9023,8 @@ msgid ""
 "documentation, alignment of PostGIS with PostgreSQL releases, X3D support, "
 "TIGER geocoder support, management functions."
 msgstr ""
+"持续集成和网站维护,Windows生产和实验构建,文档编写,将PostGIS与PostgreSQL发"
+"布版本对齐,X3D支持,TIGER地理编码支持,管理功能。"
 #. Tag: term
 #, no-c-format
@@ -9034,7 +9036,8 @@ msgstr "Darafei Praliaskouski"
 msgid ""
 "Index improvements, bug fixing and geometry/geography function improvements, "
 "SFCGAL, raster, GitHub curation, and ci maintenance."
-msgstr ""
+msgstr "索引改进,故障修复和几何/地理函数改进,SFCGAL,栅格,GitHub维护,以及持续集成"
+"维护。"
 #. Tag: term
 #, no-c-format
@@ -9065,7 +9068,8 @@ msgid ""
 "Bug fixes and maintenance, ci maintenance, git mirror management, management "
 "functions, integration of new GEOS functionality and alignment with GEOS "
 "releases, topology support, and raster framework and low level API functions."
-msgstr ""
+msgstr "错误修复和维护,持续集成维护,Git镜像管理,管理功能,集成新的GEOS功能并与GEOS"
+"发布对齐,拓扑支持,以及栅格框架和底层API函数。"
 #. Tag: title
 #, no-c-format
@@ -9095,7 +9099,7 @@ msgstr "Loïc Bartoletti"
 #. Tag: para
 #, no-c-format
 msgid "SFCGAL enhancments and maintenance and ci support"
-msgstr ""
+msgstr "SFCGAL 的增强和维护以及持续集成支持"
 #. Tag: term
 #, no-c-format
@@ -9129,7 +9133,7 @@ msgstr "Björn Harrtell"
 msgid ""
 "MapBox Vector Tile, GeoBuf, and Flatgeobuf functions. Gitea testing and "
 "GitLab experimentation."
-msgstr ""
+msgstr "MapBox 矢量瓦片、GeoBuf 和 Flatgeobuf 函数。Gitea 测试和 GitLab 实验。"
 #. Tag: term
 #, no-c-format
@@ -15648,7 +15652,7 @@ msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Example: Extends a line 5 units forward and 6 units backward"
-msgstr ""
+msgstr "例如:将一条线向前延伸5个单位,向后延伸6个单位"
 #. Tag: para
 #, no-c-format
@@ -26258,7 +26262,7 @@ msgstr "多边形三角剖分"
 #. Tag: title
 #, no-c-format
 msgid "Same example as ST_Tesselate"
-msgstr ""
+msgstr "同样的例子,如ST_Tesselate"
 #. Tag: para
 #, no-c-format
@@ -26273,13 +26277,14 @@ msgstr "原始多边形"
 #. Tag: para
 #, no-c-format
 msgid "Triangulated Polygon"
-msgstr ""
+msgstr "三角形多边形"
 #. Tag: para
 #, no-c-format
 msgid ""
 ", <xref linkend=\"ST_DelaunayTriangles\"/>, <xref linkend=\"ST_Tesselate\"/>"
 msgstr ""
+", <xref linkend=\"ST_DelaunayTriangles\"/>, <xref linkend=\"ST_Tesselate\"/>"
 #. Tag: refpurpose
 #, no-c-format
@@ -37201,7 +37206,8 @@ msgstr ""
 msgid ""
 "does similar to this function except that it returns a geometry collection "
 "of polygons instead of a TIN and also only works with 2D geometries."
-msgstr ""
+msgstr "与此函数类似,但返回一个多边形的几何集合而不是三角形网,并且仅适用于二维几何"
 #. Tag: para
 #, no-c-format
@@ -37229,12 +37235,14 @@ msgid ""
 ", <xref linkend=\"ST_DelaunayTriangles\"/>, <xref linkend="
 "\"ST_TriangulatePolygon\"/>"
 msgstr ""
+", <xref linkend=\"ST_DelaunayTriangles\"/>, <xref linkend="
+"\"ST_TriangulatePolygon\"/>"
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
 "Compute a visibility polygon from a point or a segment in a polygon geometry"
-msgstr ""
+msgstr "计算一个从点或多边形几何中的线段生成的可见性多边形"
 #. Tag: para
 #, no-c-format
@@ -37244,12 +37252,12 @@ msgstr "可用性:3.5.0 - 需要 SFCGAL >= 1.5.0。"
 #. Tag: para
 #, no-c-format
 msgid "Visibility from the point"
-msgstr ""
+msgstr "从点的视角来看,可见性"
 #. Tag: para
 #, no-c-format
 msgid "Visibility from the segment"
-msgstr ""
+msgstr "从线段的视角来看,可见性"
 #. Tag: refpurpose
 #, no-c-format
Summary of changes:
 doc/po/zh_Hans/postgis-manual.po | 32 ++++++++++++++++++++------------
 1 file changed, 20 insertions(+), 12 deletions(-)
hooks/post-receive
