[SCM] PostGIS branch master updated. 3.4.0rc1-813-gf79779012
Tue Nov 28 18:10:41 PST 2023
the project "PostGIS".
       via  f797790126102762e311e738022197c7bf417609 (commit)
       via  1597458c37f8b3c30045634dc4ce3cee8a9b8b91 (commit)
       via  741f8eb42305a06492caa0bf315bed9a54afa7d6 (commit)
       via  59aba6dcb9fc28f14bfb9aca390987c00d510a70 (commit)
      from  e688a7d3dad379a5928d3404545628ac588837b0 (commit)
revisions in full, below.
commit f797790126102762e311e738022197c7bf417609
Merge: 1597458c3 e688a7d3d
Author: Regina Obe <lr at pcorp.us>
Date:   Tue Nov 28 21:09:37 2023 -0500
    Merge branch 'master' of git.osgeo.org:postgis/postgis
commit 1597458c37f8b3c30045634dc4ce3cee8a9b8b91
Date:   Tue Nov 28 21:06:08 2023 -0500
    Add more plants
diff --git a/doc/xsl/postgis_gardentest.sql.xsl b/doc/xsl/postgis_gardentest.sql.xsl
index b0f85671b..0c642a3f3 100644
--- a/doc/xsl/postgis_gardentest.sql.xsl
+++ b/doc/xsl/postgis_gardentest.sql.xsl
@@ -311,11 +311,24 @@ FROM (VALUES ( ST_GeomFromEWKT('SRID=4326;MULTIPOLYGON(((-71.0821 42.3036 2,-71.
 					ORDER BY i, j, i*j)</pgis:gset>
 		<pgis:gset ID="Collection of Empties" GeometryType="GEOMETRY" createtable="false">(SELECT ST_Collect(ST_GeomFromText('GEOMETRYCOLLECTION EMPTY',4326), ST_GeomFromText('POLYGON EMPTY',4326)) As the_geom
-			UNION ALL SELECT ST_COLLECT(ST_GeomFromText('POLYGON EMPTY',4326),ST_GeomFromText('TRIANGLE EMPTY',4326))  As the_geom
 			UNION ALL SELECT ST_Collect(ST_GeomFromText('POINT EMPTY',4326), ST_GeomFromText('MULTIPOINT EMPTY',4326)) As the_geom
 		)</pgis:gset>
 		<pgis:gset ID="POLYGON EMPTY" GeometryType="POLYGON" createtable="false">(SELECT ST_GeomFromText('POLYGON EMPTY',4326) As the_geom)</pgis:gset>
+		<pgis:gset ID="Collection of Empties Basic" GeometryType="GEOMETRY" createtable="false">(SELECT ST_Collect(ST_GeomFromText('GEOMETRYCOLLECTION EMPTY',4326), ST_GeomFromText('POLYGON EMPTY',4326)) As the_geom
+			UNION ALL SELECT ST_Collect(ST_GeomFromText('POINT EMPTY',4326), ST_GeomFromText('MULTIPOINT EMPTY',4326)) As the_geom
+			UNION ALL SELECT ST_Collect(ST_GeomFromText('LINESTRING EMPTY',4326), ST_GeomFromText('MULTILINESTRING EMPTY',4326)) As the_geom
+		)</pgis:gset>
+		<pgis:gset ID="TIN / TRIANGLE EMPTY" GeometryType="GEOMETRY" createtable="false">(SELECT ST_GeomFromText('TRIANGLE EMPTY',4326) As the_geom
+			UNION ALL SELECT ST_GeomFromText('TIN EMPTY',4326) As the_geom
+		)</pgis:gset>
+		<pgis:gset ID="TINZ / TRIANGLEZ EMPTY" GeometryType="GEOMETRY" createtable="false">(SELECT ST_GeomFromText('TINZ EMPTY',4326) As the_geom
+			UNION ALL SELECT ST_GeomFromText('TRIANGLEZ EMPTY',4326) As the_geom
+		)</pgis:gset>
+		<pgis:gset ID="POLYGON EMPTY" GeometryType="POLYGON" createtable="false">(SELECT ST_GeomFromText('POLYGON EMPTY',4326) As the_geom)</pgis:gset>
+		<pgis:gset ID="LINESTRING EMPTY with NON-EMPTY" GeometryType="POLYGON" createtable="false">(SELECT ST_Collect(ARRAY[ST_GeomFromText('LINESTRING(0 0, 1 1)'), ST_GeomFromText('LINESTRING EMPTY')]) As the_geom)</pgis:gset>
 	<pgis:gardencrashers>
commit 741f8eb42305a06492caa0bf315bed9a54afa7d6
Date:   Tue Nov 28 20:36:46 2023 -0500
    FIX FOR gardentest arg inputs
    Closes #5625
index bd1dcfb1c..b0f85671b 100644
@@ -528,14 +528,14 @@ SELECT '<xsl:value-of select="$log_label" /> Geography: End Testing';
 		<xsl:sort select="@id"/>
 			<xsl:for-each select="db:refsynopsisdiv/db:funcsynopsis/db:funcprototype">
-<!--Create dummy parameters to be used later -->
+<!--Create dummy db:parameters to be used later -->
 				<xsl:variable name='fnfakeparams'><xsl:call-template name="replaceparams"><xsl:with-param name="func" select="." /></xsl:call-template></xsl:variable>
 				<xsl:variable name='fnargs'><xsl:call-template name="listparams"><xsl:with-param name="func" select="." /></xsl:call-template></xsl:variable>
 				<xsl:variable name='fnname'><xsl:value-of select="db:funcdef/db:function"/></xsl:variable>
 				<xsl:variable name='fndef'><xsl:value-of select="db:funcdef"/></xsl:variable>
-				<xsl:variable name='numparams'><xsl:value-of select="count(db:paramdef/parameter)" /></xsl:variable>
+				<xsl:variable name='numparams'><xsl:value-of select="count(db:paramdef/db:parameter)" /></xsl:variable>
-				<xsl:variable name='numparamgeoms'><xsl:value-of select="count(db:paramdef/db:type[contains(text(),'geometry') or contains(text(),'geography') or contains(text(),'box') or contains(text(), 'bytea') or contains(text(),'anyelement')] ) + count(db:paramdef/parameter[contains(text(),'WKT')]) + count(db:paramdef/parameter[contains(text(),'geomgml')]) + count(db:paramdef/parameter[contains(text(),'geomjson')]) + count(db:paramdef/parameter[contains(text(),'geomkml')])" /></xsl:variable>
+				<xsl:variable name='numparamgeoms'><xsl:value-of select="count(db:paramdef/db:type[contains(text(),'geometry') or contains(text(),'geography') or contains(text(),'box') or contains(text(), 'bytea') or contains(text(),'anyelement')] ) + count(db:paramdef/db:parameter[contains(text(),'WKT')]) + count(db:paramdef/db:parameter[contains(text(),'geomgml')]) + count(db:paramdef/db:parameter[contains(text(),'geomjson')]) + count(db:paramdef/db:parameter[contains(text(),'geomkml')])" /></xsl:variable>
 				<xsl:variable name='numparamgeogs'><xsl:value-of select="count(db:paramdef/db:type[contains(text(),'geography')] )" /></xsl:variable>
 				<xsl:variable name='log_label'><xsl:value-of select="db:funcdef/db:function" />(<xsl:value-of select="$fnargs" />)</xsl:variable>
@@ -662,140 +662,140 @@ SELECT '<xsl:value-of select="$fnname" /><xsl:text> </xsl:text><xsl:value-of sel
 			<xsl:for-each select="db:paramdef">
 				<xsl:choose>
 				    <!-- ignore output parameters -->
-				    <xsl:when test="contains(parameter,'OUT')"></xsl:when>
-				    	<xsl:when test="contains(parameter, 'buffer_style_parameters') or contains(parameter, 'buffer_style_parameters')">
+				    <xsl:when test="contains(db:parameter,'OUT')"></xsl:when>
+				    	<xsl:when test="contains(db:parameter, 'buffer_style_parameters') or contains(db:parameter, 'buffer_style_parameters')">
 						<xsl:value-of select="$var_buffer_style" />
 					</xsl:when>
-					<xsl:when test="contains(parameter, 'matrix') or contains(parameter, 'Matrix')">
+					<xsl:when test="contains(db:parameter, 'matrix') or contains(db:parameter, 'Matrix')">
 						<xsl:value-of select="$var_matrix" />
 					</xsl:when>
-					<xsl:when test="contains(parameter, 'distance')">
+					<xsl:when test="contains(db:parameter, 'distance')">
 						<xsl:value-of select="$var_distance" />
 					</xsl:when>
-					<xsl:when test="contains(parameter, 'row')">
+					<xsl:when test="contains(db:parameter, 'row')">
 						<xsl:value-of select="$var_row" />
 					</xsl:when>
-					<xsl:when test="contains(parameter, 'srid')">
+					<xsl:when test="contains(db:parameter, 'srid')">
 						<xsl:value-of select="$var_srid" />
 					</xsl:when>
-					<xsl:when test="contains(parameter, 'position')">
+					<xsl:when test="contains(db:parameter, 'position')">
 						<xsl:value-of select="$var_position" />
 					</xsl:when>
-					<xsl:when test="contains(parameter, 'NDR')">
+					<xsl:when test="contains(db:parameter, 'NDR')">
 						'<xsl:value-of select="$var_NDRXDR" />'
 					</xsl:when>
-					<xsl:when test="contains(parameter, 'gj_version')">
+					<xsl:when test="contains(db:parameter, 'gj_version')">
 						<xsl:value-of select="$var_gj_version" />
 					</xsl:when>
-					<xsl:when test="contains(parameter, 'version') and position() = 2">
+					<xsl:when test="contains(db:parameter, 'version') and position() = 2">
 						<xsl:value-of select="$var_version1" />
 					</xsl:when>
-					<xsl:when test="(contains(parameter, 'version'))">
+					<xsl:when test="(contains(db:parameter, 'version'))">
 						<xsl:value-of select="$var_version2" />
 					</xsl:when>
-					<xsl:when test="(contains(parameter,'geomgml'))">
+					<xsl:when test="(contains(db:parameter,'geomgml'))">
 						<xsl:text>ST_AsGML(foo1.the_geom)</xsl:text>
 					</xsl:when>
-					<xsl:when test="(contains(parameter,'geomkml'))">
+					<xsl:when test="(contains(db:parameter,'geomkml'))">
 						<xsl:text>ST_AsKML(foo1.the_geom)</xsl:text>
 					</xsl:when>
-					<xsl:when test="(contains(parameter,'geomjson'))">
+					<xsl:when test="(contains(db:parameter,'geomjson'))">
 						<xsl:text>ST_AsGeoJSON(foo1.the_geom)</xsl:text>
 					</xsl:when>
-					<xsl:when test="contains(parameter, 'geom_name')">
+					<xsl:when test="contains(db:parameter, 'geom_name')">
 						'<xsl:value-of select="$var_geom_name" />'
 					</xsl:when>
-					<xsl:when test="contains(parameter, 'bounds')">
+					<xsl:when test="contains(db:parameter, 'bounds')">
 						ST_MakeBox2D(ST_Point(0, 0), ST_Point(4096, 4096))
 					</xsl:when>
-					<xsl:when test="(contains(type,'box') or type = 'geometry' or type = 'geometry ' or contains(type,'geometry set') or contains(type,'geometry winset') ) and (position() = 1 or count($func/paramdef/db:type[contains(text(),'geometry') or contains(text(),'box') or contains(text(), 'WKT') or contains(text(), 'bytea')]) = '1')">
+					<xsl:when test="(contains(db:type,'box') or db:type = 'geometry' or db:type = 'geometry ' or contains(db:type,'geometry set') or contains(db:type,'geometry winset') ) and (position() = 1 or count($func/db:paramdef/db:type[contains(text(),'geometry') or contains(text(),'box') or contains(text(), 'WKT') or contains(text(), 'bytea')]) = '1')">
 						<xsl:text>foo1.the_geom</xsl:text>
 					</xsl:when>
-					<xsl:when test="(type = 'geography' or type = 'geography ' or contains(type,'geography set')) and (position() = 1 or count($func/paramdef/db:type[contains(text(),'geography')]) = '1' )">
+					<xsl:when test="(db:type = 'geography' or db:type = 'geography ' or contains(db:type,'geography set')) and (position() = 1 or count($func/paramdef/db:type[contains(text(),'geography')]) = '1' )">
 						<xsl:text>geography(foo1.the_geom)</xsl:text>
 					</xsl:when>
-					<xsl:when test="contains(type,'box') or type = 'geometry' or type = 'geometry '">
+					<xsl:when test="contains(db:type,'box') or db:type = 'geometry' or db:type = 'geometry '">
 						<xsl:text>foo2.the_geom</xsl:text>
 					</xsl:when>
-					<xsl:when test="type = 'geography' or type = 'geography '">
+					<xsl:when test="db:type = 'geography' or db:type = 'geography '">
 						<xsl:text>geography(foo2.the_geom)</xsl:text>
 					</xsl:when>
-					<xsl:when test="contains(type, 'bigint[]')">
+					<xsl:when test="contains(db:type, 'bigint[]')">
 						<xsl:text>ARRAY[ST_XMin(foo1.the_geom)::bigint]</xsl:text>
 					</xsl:when>
-					<xsl:when test="contains(type, 'geometry[]') and count($func/paramdef/db:type[contains(text(),'geometry') or contains(text(),'box') or contains(text(), 'WKT') or contains(text(), 'bytea')]) = '1'">
+					<xsl:when test="contains(db:type, 'geometry[]') and count($func/paramdef/db:type[contains(text(),'geometry') or contains(text(),'box') or contains(text(), 'WKT') or contains(text(), 'bytea')]) = '1'">
 						ARRAY[foo1.the_geom]
 					</xsl:when>
-					<xsl:when test="contains(type, 'geometry[]')">
+					<xsl:when test="contains(db:type, 'geometry[]')">
 						ARRAY[foo2.the_geom]
 					</xsl:when>
-					<xsl:when test="contains(parameter, 'EWKT')">
+					<xsl:when test="contains(db:parameter, 'EWKT')">
 						<xsl:text>ST_AsEWKT(foo1.the_geom)</xsl:text>
 					</xsl:when>
-					<xsl:when test="contains(parameter, 'WKT')">
+					<xsl:when test="contains(db:parameter, 'WKT')">
 						<xsl:text>ST_AsText(foo1.the_geom)</xsl:text>
 					</xsl:when>
-					<xsl:when test="contains(parameter, 'EWKB')">
+					<xsl:when test="contains(db:parameter, 'EWKB')">
 						<xsl:text>ST_AsEWKB(foo1.the_geom)</xsl:text>
 					</xsl:when>
-					<xsl:when test="contains(parameter, 'twkb')">
+					<xsl:when test="contains(db:parameter, 'twkb')">
 						<xsl:text>ST_AsTWKB(foo1.the_geom)</xsl:text>
 					</xsl:when>
-					<xsl:when test="contains(type, 'bytea')">
+					<xsl:when test="contains(db:type, 'bytea')">
 						<xsl:text>ST_AsBinary(foo1.the_geom)</xsl:text>
 					</xsl:when>
-					<xsl:when test="contains(parameter, 'Frac') or contains(parameter, 'frac') or contains(parameter, 'percent')">
+					<xsl:when test="contains(db:parameter, 'Frac') or contains(db:parameter, 'frac') or contains(db:parameter, 'percent')">
 						<xsl:value-of select="$var_frac" />
 					</xsl:when>
-					<xsl:when test="contains(type, 'float') or contains(type, 'double')">
+					<xsl:when test="contains(db:type, 'float') or contains(db:type, 'double')">
 						<xsl:value-of select="$var_float1" />
 					</xsl:when>
-					<xsl:when test="contains(type, 'spheroid')">
+					<xsl:when test="contains(db:type, 'spheroid')">
 						<xsl:value-of select="$var_spheroid" />
 					</xsl:when>
-					<xsl:when test="contains(type, 'integer') and position() = 2">
+					<xsl:when test="contains(db:type, 'integer') and position() = 2">
 						<xsl:value-of select="$var_integer1" />
 					</xsl:when>
-					<xsl:when test="contains(type, 'integer') or contains(type, 'int4')">
+					<xsl:when test="contains(db:type, 'integer') or contains(db:type, 'int4')">
 						<xsl:value-of select="$var_integer2" />
 					</xsl:when>
-					<xsl:when test="contains(type, 'text')">
+					<xsl:when test="contains(db:type, 'text')">
 						<xsl:value-of select="$var_text" />
 					</xsl:when>
-					<xsl:when test="contains(type, 'varchar')">
+					<xsl:when test="contains(db:type, 'varchar')">
 						<xsl:value-of select="$var_varchar" />
 					</xsl:when>
-					<xsl:when test="contains(type,'timestamp') or type = 'date'">
+					<xsl:when test="contains(db:type,'timestamp') or db:type = 'date'">
 						<xsl:text>'2009-01-01'</xsl:text>
 					</xsl:when>
-					<xsl:when test="contains(type,'boolean')">
+					<xsl:when test="contains(db:type,'boolean')">
 						<xsl:value-of select="$var_boolean" />
 					</xsl:when>
 				</xsl:choose>
 				<!-- put a comma before an arg if it is not the first argument in a function and it is not an OUT parameter nor does it precede an OUT parameter -->
-				<xsl:if test="position()<last() and not(contains(parameter,'OUT')) and not(contains(following-sibling::paramdef[1],'OUT'))"><xsl:text>, </xsl:text></xsl:if>
+				<xsl:if test="position()<last() and not(contains(db:parameter,'OUT')) and not(contains(following-sibling::paramdef[1],'OUT'))"><xsl:text>, </xsl:text></xsl:if>
 			</xsl:for-each>
 		</xsl:for-each>
 	</xsl:template>
-	<!--macro to pull out function parameter names so we can provide a pretty arg list prefix for each function -->
+	<!--macro to pull out function db:parameter names so we can provide a pretty arg list prefix for each function -->
 	<xsl:template name="listparams">
 		<xsl:param name="func" />
 		<xsl:for-each select="$func">
-			<xsl:if test="count(db:paramdef/parameter) > 0"> </xsl:if>
+			<xsl:if test="count(db:paramdef/db:parameter) > 0"> </xsl:if>
 				<xsl:choose>
-					<xsl:when test="count(parameter) > 0">
-						<xsl:value-of select="parameter" />
+					<xsl:when test="count(db:parameter) > 0">
+						<xsl:value-of select="db:parameter" />
 					</xsl:when>
 				</xsl:choose>
 				<xsl:if test="position()<last()"><xsl:text>, </xsl:text></xsl:if>
diff --git a/doc/xsl/raster_gardentest.sql.xsl b/doc/xsl/raster_gardentest.sql.xsl
index 03fab2c1b..aa0f61998 100644
--- a/doc/xsl/raster_gardentest.sql.xsl
+++ b/doc/xsl/raster_gardentest.sql.xsl
@@ -251,10 +251,10 @@ COMMIT;
-				<xsl:variable name='numparamgeoms'><xsl:value-of select="count(db:paramdef/db:type[contains(text(),'geometry') or contains(text(),'geography') or contains(text(),'box') ]) + count(db:paramdef/parameter[contains(text(),'WKT')]) + count(db:paramdef/parameter[contains(text(),'geomgml')])" /></xsl:variable>
+				<xsl:variable name='numparamgeoms'><xsl:value-of select="count(db:paramdef/db:type[contains(text(),'geometry') or contains(text(),'geography') or contains(text(),'box') ]) + count(db:paramdef/db:parameter[contains(text(),'WKT')]) + count(db:paramdef/db:parameter[contains(text(),'geomgml')])" /></xsl:variable>
 				<xsl:variable name='numparamrasts'><xsl:value-of select="count(db:paramdef/db:type[contains(text(),'raster') ] )" /></xsl:variable>
-				<xsl:variable name='log_label'><xsl:value-of select="db:funcdef/db:function" />(<xsl:value-of select="$fnargs" />)</xsl:variable>
+				<xsl:variable name='log_label'><xsl:value-of select="db:funcdef/db:function" />(<xsl:value-of select="$fnargs" />) </xsl:variable>
 				<xsl:variable name="geoftype">
 				  <!--Conditionally instantiate a value to be assigned to the variable -->
@@ -416,150 +416,150 @@ SELECT '<xsl:value-of select="$fnname" /><xsl:text> </xsl:text><xsl:value-of sel
 				<xsl:choose>
-				    <xsl:when test="contains(parameter, 'algorithm')">
+				    <xsl:when test="contains(db:parameter, 'algorithm')">
 						<xsl:value-of select="$var_algorithm" />
 					</xsl:when>
-					<xsl:when test="contains(parameter, 'georefcoords')">
+					<xsl:when test="contains(db:parameter, 'georefcoords')">
 						<xsl:value-of select="$var_georefcoords" />
 					</xsl:when>
-					<xsl:when test="(type = 'integer[]'  )">
+					<xsl:when test="(db:type = 'integer[]'  )">
 						ARRAY[<xsl:value-of select="$var_integer1" />]
 					</xsl:when>
-					<xsl:when test="contains(parameter, 'index') or contains(parameter, 'band') or contains(parameter, 'nband')">
+					<xsl:when test="contains(db:parameter, 'index') or contains(db:parameter, 'band') or contains(db:parameter, 'nband')">
 						<xsl:value-of select="$var_band" />
 					</xsl:when>
-					<xsl:when test="contains(parameter, 'rastercolumn')">
+					<xsl:when test="contains(db:parameter, 'rastercolumn')">
 						<xsl:value-of select="$var_rastercolumn" />
 					</xsl:when>
-					<xsl:when test="contains(parameter, 'rastertable')">
+					<xsl:when test="contains(db:parameter, 'rastertable')">
 						<xsl:value-of select="$var_rastertable" />
 					</xsl:when>
-					<xsl:when test="contains(parameter, 'format')">
+					<xsl:when test="contains(db:parameter, 'format')">
 						<xsl:value-of select="$var_format" />
 					</xsl:when>
-					<xsl:when test="contains(parameter, 'options')">
+					<xsl:when test="contains(db:parameter, 'options')">
 						<xsl:value-of select="$var_options" />
 					</xsl:when>
-					<xsl:when test="contains(parameter, 'pt')">
+					<xsl:when test="contains(db:parameter, 'pt')">
 						<xsl:value-of select="$var_pt" />
 					</xsl:when>
-					<xsl:when test="contains(parameter, 'pixeltype')">
+					<xsl:when test="contains(db:parameter, 'pixeltype')">
 						<xsl:value-of select="$var_pixeltype" />
 					</xsl:when>
 					</xsl:when>
 					</xsl:when>
 					</xsl:when>
 					</xsl:when>
-					<xsl:when test="contains(parameter, 'onerasteruserfunc')">
+					<xsl:when test="contains(db:parameter, 'onerasteruserfunc')">
 						<xsl:value-of select="$var_onerasteruserfunc" />
 					</xsl:when>
 					</xsl:when>
-					<xsl:when test="contains(parameter, 'addbandargset')">
+					<xsl:when test="contains(db:parameter, 'addbandargset')">
 						<xsl:value-of select="$var_addbandargset" />
 					</xsl:when>
-					<xsl:when test="(contains(type,'box') or type = 'geometry' or type = 'geometry ' or contains(type,'geometry set')) and (position() = 1 or count($func/paramdef/db:type[contains(text(),'geometry') or contains(text(),'box') or contains(text(), 'WKT') or contains(text(), 'bytea')]) = '1')">
+					<xsl:when test="(contains(db:type,'box') or db:type = 'geometry' or db:type = 'geometry ' or contains(type,'geometry set')) and (position() = 1 or count($func/paramdef/db:type[contains(text(),'geometry') or contains(text(),'box') or contains(text(), 'WKT') or contains(text(), 'bytea')]) = '1')">
 						<xsl:text>rast1.rast::geometry</xsl:text>
 					</xsl:when>
 						<xsl:text>rast1.rast::geometry::geography</xsl:text>
 					</xsl:when>
 						<xsl:text>rast2.rast::geometry</xsl:text>
 					</xsl:when>
 						<xsl:text>geography(rast2.rast::geometry)</xsl:text>
 					</xsl:when>
-					<xsl:when test="contains(type,'raster[]') and (position() = 1) ">
+					<xsl:when test="contains(db:type,'raster[]') and (position() = 1) ">
 						<xsl:text>ARRAY[rast1.rast]</xsl:text>
 					</xsl:when>
-					<xsl:when test="contains(type, 'raster[]') ">
+					<xsl:when test="contains(db:type, 'raster[]') ">
 						<xsl:text>ARRAY[rast2.rast]</xsl:text>
 					</xsl:when>
-					<xsl:when test="(type = 'raster' or type = 'raster ' or contains(type, 'raster set') or contains(type, 'setof raster') ) and (position() = 1) ">
+					<xsl:when test="(db:type = 'raster' or db:type = 'raster ' or contains(db:type, 'raster set') or contains(db:type, 'setof raster') ) and (position() = 1) ">
 						<xsl:text>rast1.rast</xsl:text>
 					</xsl:when>
-					<xsl:when test="type = 'raster' or type = 'raster ' or contains(type, 'raster set')or contains(type, 'setof raster')">
+					<xsl:when test="db:type = 'raster' or db:type = 'raster ' or contains(db:type, 'raster set') or contains(db:type, 'setof raster')">
 						<xsl:text>rast2.rast</xsl:text>
 					</xsl:when>
-					<xsl:when test="type = 'raster' or type = 'raster ' or contains(type, 'raster set') or contains(type, 'setof raster')">
 					</xsl:when>
+					<xsl:when test="contains(db:type, 'geometry[]') and count($func/db:paramdef/db:type[contains(text(),'geometry') or contains(text(),'box') or contains(text(), 'WKT') or contains(text(), 'bytea')]) = '1'">
 					</xsl:when>
 					</xsl:when>
 					</xsl:when>
 					</xsl:when>
 					</xsl:when>
 					</xsl:when>
 					</xsl:when>
 					</xsl:when>
 					</xsl:when>
-					<xsl:when test="contains(type, 'integer')">
+					<xsl:when test="contains(db:type, 'integer')">
 					</xsl:when>
-					<xsl:when test="contains(type,'reclassarg')">
+					<xsl:when test="contains(db:type,'reclassarg')">
 						<xsl:value-of select="$var_reclassarg" />
 					</xsl:when>
 					</xsl:when>
 					</xsl:when>
 					</xsl:when>
 					</xsl:when>
 				</xsl:choose>
+				<xsl:if test="position()<last() and not(contains(db:parameter,'OUT')) and not(contains(following-sibling::db:paramdef[1],'OUT'))"><xsl:text>, </xsl:text></xsl:if>
 			</xsl:for-each>
 		</xsl:for-each>
 	</xsl:template>
 				<xsl:choose>
-					<xsl:when test="count(db:paramdef/parameter) > 0">
-						<xsl:value-of select="db:paramdef/parameter" />
 					</xsl:when>
 				</xsl:choose>
commit 59aba6dcb9fc28f14bfb9aca390987c00d510a70
Date:   Mon Nov 27 19:34:13 2023 -0500
    Add #5596 (ST_AsGeoJSON id enhancement to
    Enhancements section as well
diff --git a/NEWS b/NEWS
index ea4a9a9e3..578741b79 100644
--- a/NEWS
+++ b/NEWS
@@ -41,6 +41,8 @@ To take advantage of all SFCGAL featurs, SFCGAL 1.5.0+ is needed.
   - #5531, documentation format upgraded to DocBook 5 (Sandro Santilli)
   - #5543, allow building without documentation (Sandro Santilli)
+  - #5596, GH-749, Allow promoting column as an id
+          in ST_AsGeoJson(record,..). (Jan Tojnar)
 PostGIS 3.4.0
Summary of changes:
 NEWS                               |   2 +
 doc/xsl/postgis_gardentest.sql.xsl | 105 +++++++++++++++++++++----------------
 doc/xsl/raster_gardentest.sql.xsl  | 100 +++++++++++++++++------------------
 3 files changed, 111 insertions(+), 96 deletions(-)
hooks/post-receive
