[PostGIS] #5626: ST_LargestEmptyCircle crashes on GEOS 3.13 with Triangle
PostGIS trac at osgeo.org
Tue Nov 28 19:43:28 PST 2023
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 3.5.0
Component:  postgis  |    Version:  3.4.x
 Keywords:           |
 SELECT ST_LargestEmptyCircle('POINT(-11.1111111 40)'::geometry, 20.1,
 'TRIANGLE((-71.0821 42.3036,-71.0821 42.3936,-71.0901 42.3036,-71.0821
 42.3036))'::geometry )
 berrie64 which also does crasher tests seems to have gone thru fine
 (though I just checked and she's only testing GEOS 3.12.0 so have to up
 that), so maybe this only affects GEOS 3.13.
 I'm running with a week old geos, and will test after my latest is
 rebuilt.
 I'm surprised GEOS even works with triangles.  When did this happen.
 Should it be erroring out, or does GEOS now support triangles?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5626>
