[postgis-tickets] [PostGIS] #5564: BRIN indexes cause server crash after continuous autovacuum
PostGIS trac at osgeo.org
Tue Oct 3 13:17:58 PDT 2023
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 3.5.0
Component:  postgis  |    Version:  3.1.x
 Keywords:           |
 Under intense conditions of autovacuuming of a geometry BRIN indexed
 tables, crashes have been found to occur.
 Fixes suggested by Giuseppe Broccolo suggested
 How to fix:
 1. Define a MERGE support function and add it in the OpClass
 2. Define a new UNION support function, similar to the ADD_VALUE one, that
 override the Postgresql core one in the OpClass (note that the MERGE
 support function is only used by ADD_VALUE and UNION)
 Solution 2. is maybe the most consistent with the current implementation
 in PostGIS due to the peculiarity of geospatial data type in order to be
 indexed, that originally brought us to redefine (and simplify compared to
 Postgresql core version) the ADD_VALUE function. But I would like to hear
 about other opinions regarding this.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5564>
