[postgis-tickets] [PostGIS] #5564: BRIN indexes cause server crash after continuous autovacuum
PostGIS trac at osgeo.org
Tue Oct 3 13:21:29 PDT 2023
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.5.0
 Component:  postgis  |    Version:  3.1.x
Resolution:           |   Keywords:
Description changed by robe:
Old description:
> Under intense conditions of autovacuuming of a geometry BRIN indexed
> tables, crashes have been found to occur.
> Fixes suggested by Giuseppe Broccolo suggested
> How to fix:
> 1. Define a MERGE support function and add it in the OpClass
> 2. Define a new UNION support function, similar to the ADD_VALUE one,
> that override the Postgresql core one in the OpClass (note that the MERGE
> support function is only used by ADD_VALUE and UNION)
> Solution 2. is maybe the most consistent with the current implementation
> in PostGIS due to the peculiarity of geospatial data type in order to be
> indexed, that originally brought us to redefine (and simplify compared to
> Postgresql core version) the ADD_VALUE function. But I would like to hear
> about other opinions regarding this.
New description:
 How to fix:
 2. Define a new UNION support function, similar to the ADD_VALUE one, that
 The gdb backtrace of this issue:
 #0 FunctionCall2Coll(fcinfo=0x0 collation-collationcentry=0x0 arg
 =232/28/1391480| arg2=232728/1252344) at tmgr.c:1306\n
 #1 0x0000000000603533 in brin_inclusion_union (fcinfo=<optimized out>) at
 brin_inclusion.c:522\n
 #2 0x0000000000a9be34 in FunctionCal13Coll (flinfo=0×152d885cf98|
 collation=optimizedout>|
 arg1=argi at entry=23285305342184| arg2=arg2 at entry=23272870259120|
 arg3=arg3 at entry=23272871440776) at
 fmgr.c:1331\n
 #3 0x0000000000601ea6 in union_tuples (b=0x152aa33c9278| a=<optimized
 out>| bdesc=<optimized
 out>) at brin.c:1651 \n
 #4 summarize_range CheapNumBlks=53390|heapBIk=43520|
 heapRel=0x152d88748a98|
 state=<optimized out>| indexInfo=0x152a33c9518) at brin.c:1460\n
 #5 brinsummarize
 index=0x152d88749b48|heapRel=heapRel at entry=0x152d88748a98|
 pageRange=pageRange at entry=4294967295|
 include_partial=include_partial at entry-false| numSummarized-
 numSummarized at entry=0×152aa32a3308|
 numExisting=numExisting at entry=0x152a32a3308) at brin.c:1542\n
 #6 0x000000000060219a in brinvacuumcleanup(info=0x7ffd2a9740b0|
 stats=<optimized out>) at brin.c:957\n
 #7 0x0000000000652280 in lazy_cleanup_one_index
 (indrel=0x152088749648| 1stat=0x152aa32 at 3300|
 reltuples=reltuples at entry=176649|
 estimated_count=estimated_count at entry=true|
 vacrel=vacrel at entry=0x152a33c9628) at vacuumlazy.c:3404\n
 #8 0x0000000000654f74 in lazy_cleanup_all_indexes (vacrel=8x152aa33c9628)
 at vacuumlazy.c:3295\n
 #9 lazy_scan_heap (aggressive=false| params=0x152d88785ac|
 vacrel=<optimized out>) at vacuumlazy.c: 1851\n
 #10 heap_vacuum_rel (rel=0x152088748298| params=0x152d8878f5ac|
 bstrategy=<optimized out>) at
 vacuumlazy.c:746\n/
 #11 0x00000000007bflba in table_relation_vacuum (bstrategy-<optimized
 out>|
 params=0x152d8878f5ac| rel=0x152d88748a98) at
 ../../../src/include/access/tableam.h:1682\n
 #12 vacuum_rel(relid=1830312108| relation=<optimized out>|
 params=params at entry=0x152d8878f5ac) at vacuum. c: 2122\n
 #13 0x00000000007c065c in vacuum (relations=0×152aa33a188|
 params=params at entry=0×152d8878f5ac|
 bstrategy=<optimized out>| bstrategy at entry=0×152aa33dba38|
 isTopLevel=isTopLevel at entry=true) at
 vacuum. c:494\n
 #14 0x00000000005d3ba7 in autovacuum_do_vac_analyze
 (bstrategy=0×152aa33d0038|
 tab=0x152d8878f5a8 at autovacuum.c:3267\n
 #15 do_autovacuum ( at autovacuum.c: 2507\n
 #16 0x00000000005041b7 in AutoVackorkerMain(arg=0x0| a r g = 0 )a t
 autovacuum.c:1728\n
 #17 0x00000000008bbob in StartAutoVacWorker( at autovacuum.c:1512\n
 #18 0x00000000008c3fc in StartAutovacuumWorker ( at postmaster.c:6885\n
 #19 sigusr1_handler (postgres_signal_arg=<optimized out>) at
 postmaster.c:6313\
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5564#comment:1>
