[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-663-g85d38455b
Thu Oct 5 17:23:45 PDT 2023
the project "PostGIS".
       via  85d38455be2b1ab63a16a57fba02e33541e01628 (commit)
      from  016b4edca8acf3b2e1b8fec28f995dfbb0700ec1 (commit)
revisions in full, below.
commit 85d38455be2b1ab63a16a57fba02e33541e01628
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Oct 5 22:38:50 2023 +0000
    Translated PostGIS Manual using Weblate (Italian)
    Currently translated at 25.8% (1447 of 5603 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/it/
diff --git a/doc/po/it_IT/postgis-manual.po b/doc/po/it_IT/postgis-manual.po
index 97587ccac..accee3ee1 100644
--- a/doc/po/it_IT/postgis-manual.po
+++ b/doc/po/it_IT/postgis-manual.po
@@ -6,10 +6,10 @@ msgstr ""
 "Project-Id-Version: postgis 3.5\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2023-09-28 10:07+0000\n"
-"PO-Revision-Date: 2023-09-25 16:23+0000\n"
+"PO-Revision-Date: 2023-10-06 00:23+0000\n"
 "Last-Translator: Sandro Santilli <strk at kbt.io>\n"
-"Language-Team: Italian <https://weblate.osgeo.org/projects/postgis/postgis-"
-"manual/it/>\n"
+"Language-Team: Italian <https://weblate.osgeo.org/projects/postgis/"
+"postgis-manual/it/>\n"
 "Language: it_IT\n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=UTF-8\n"
@@ -1769,6 +1769,10 @@ msgid ""
 "pretyp, suftype, qualif) (ie ARC_C plus CIVIC_C). These rules are not used "
 "in the build phase."
 msgstr ""
+"(numero di token = \"<emphasis role=\"bold\">1</emphasis>\"). La classe di "
+"regole per il parsing delle clausole MICRO complete (come House, street, "
+"sufdir, predir, pretyp, suftype, qualif) (cioè ARC_C più CIVIC_C). Queste "
+"regole non vengono utilizzate nella fase di compilazione."
 #. Tag: para
 #, no-c-format
@@ -1790,6 +1794,10 @@ msgid ""
 "rules for parsing MICRO clauses, excluding the HOUSE attribute. As such uses "
 "same set of output tokens as MICRO_C minus the HOUSE token."
 msgstr ""
+"(numero di token = \"<emphasis role=\"bold\">2</emphasis>\"). Classe di "
+"regole per il parsing delle clausole MICRO, escluso l'attributo HOUSE. Come "
+"tale, utilizza lo stesso insieme di token di output di MICRO_C, meno il "
+"token HOUSE."
 #. Tag: para
 #, no-c-format
@@ -1797,6 +1805,8 @@ msgid ""
 "(token number = \"<emphasis role=\"bold\">3</emphasis>\"). The class of "
 "rules for parsing the HOUSE attribute."
 msgstr ""
+"(numero di token = \"<emphasis role=\"bold\">3</emphasis>\"). La classe di "
+"regole per il parsing dell'attributo HOUSE."
 #. Tag: para
 #, no-c-format
@@ -1805,6 +1815,9 @@ msgid ""
 "rules for parsing EXTRA attributes - attributes excluded from geocoding. "
 "These rules are not used in the build phase."
 msgstr ""
+"(numero di token = \"<emphasis role=\"bold\">4</emphasis>\"). La classe di "
+"regole per il parsing degli attributi EXTRA - attributi esclusi dalla "
+"geocodifica. Queste regole non vengono utilizzate nella fase di costruzione."
 #. Tag: para
 #, no-c-format
@@ -1823,6 +1836,8 @@ msgstr ""
 #, no-c-format
 msgid "(token number <code>0</code>): Unparsed building identifiers and types."
 msgstr ""
+"(numero di token <code>0</code>): Identificatori e tipi di edifici non "
+"analizzati."
 #. Tag: para
 #, no-c-format
Summary of changes:
 doc/po/it_IT/postgis-manual.po | 21 ++++++++++++++++++---
 1 file changed, 18 insertions(+), 3 deletions(-)
hooks/post-receive
