[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-664-gf62ef66b6
Thu Oct 5 23:19:57 PDT 2023
the project "PostGIS".
       via  f62ef66b699e9e85e5a6798f1118e571c6b4116c (commit)
      from  85d38455be2b1ab63a16a57fba02e33541e01628 (commit)
revisions in full, below.
commit f62ef66b699e9e85e5a6798f1118e571c6b4116c
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Oct 6 02:17:53 2023 -0400
    Add reference to ST_3DDWithin on ST_3DDIntersects. References #5447
diff --git a/doc/po/templates/postgis-manual.pot b/doc/po/templates/postgis-manual.pot
index e2b1484bb..3418a21ce 100644
--- a/doc/po/templates/postgis-manual.pot
+++ b/doc/po/templates/postgis-manual.pot
@@ -6,7 +6,7 @@ msgid ""
 msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
-"POT-Creation-Date: 2023-09-28 10:07+0000\n"
+"POT-Creation-Date: 2023-10-06 06:13+0000\n"
 "PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
 "Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
 "Language-Team: LANGUAGE <kde-i18n-doc at kde.org>\n"
@@ -29530,6 +29530,16 @@ msgstr ""
 msgid "&index_aware;"
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Because of floating robustness failures, geometries don't always intersect "
+"as you'd expect them to after geometric processing. For example the closest "
+"point on a linestring to a geometry may not lie on the linestring. For these "
+"kind of issues where a distance of a centimeter you want to just consider as "
+"intersecting, use <xref linkend=\"ST_3DDWithin\"/>."
+msgstr ""
 #. Tag: para
 #, no-c-format
 msgid "Changed: 3.0.0 SFCGAL backend removed, GEOS backend supports TINs."
@@ -29540,6 +29550,11 @@ msgstr ""
 msgid "TIN Examples"
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ", <xref linkend=\"ST_Intersects\"/>"
+msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
diff --git a/doc/reference_relationship.xml b/doc/reference_relationship.xml
index 049af9fd7..b1570598d 100644
--- a/doc/reference_relationship.xml
+++ b/doc/reference_relationship.xml
@@ -39,7 +39,8 @@
         returns true, then the geometries also spatially intersect.
         Disjoint implies false for spatial intersection.</para>
-            <note><para>&index_aware;</para></note>
+      <note><para>&index_aware;</para></note>
+      <note><para>Because of floating robustness failures, geometries don't always intersect as you'd expect them to after geometric processing. For example the closest point on a linestring to a geometry may not lie on the linestring. For these kind of issues where a distance of a centimeter you want to just consider as intersecting, use <xref linkend="ST_3DDWithin"/>.</para></note>
       <para role="changed" conformance="3.0.0">Changed: 3.0.0 SFCGAL backend removed, GEOS backend supports TINs.</para>
       <para role="availability" conformance="2.0.0">Availability: 2.0.0</para>
@@ -69,7 +70,7 @@
     <refsection>
       <title>See Also</title>
-      <para><xref linkend="ST_Intersects"/></para>
+      <para><xref linkend="ST_3DDWithin"/>, <xref linkend="ST_Intersects"/></para>
     </refsection>
   </refentry>
Summary of changes:
 doc/po/templates/postgis-manual.pot | 17 ++++++++++++++++-
 doc/reference_relationship.xml      |  5 +++--
 2 files changed, 19 insertions(+), 3 deletions(-)
hooks/post-receive
