[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-667-g5c3c66a92
Fri Oct 6 20:23:46 PDT 2023
the project "PostGIS".
       via  5c3c66a9282b3472bb161f61d1e762789cf4928b (commit)
      from  23bd70e51715a29263079cb8a03ac82e4e9d4a8c (commit)
revisions in full, below.
commit 5c3c66a9282b3472bb161f61d1e762789cf4928b
Author: Zuochenwei <zuochenwei5 at gmail.com>
Date:   Sat Oct 7 01:25:16 2023 +0000
    Translated PostGIS Manual using Weblate (Chinese (Simplified))
    Currently translated at 100.0% (5605 of 5605 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/zh_Hans/
diff --git a/doc/po/zh_Hans/postgis-manual.po b/doc/po/zh_Hans/postgis-manual.po
index 6b245b94f..2dc6b8540 100644
--- a/doc/po/zh_Hans/postgis-manual.po
+++ b/doc/po/zh_Hans/postgis-manual.po
@@ -6,7 +6,7 @@ msgstr ""
 "Project-Id-Version: postgis 3.5\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2023-10-06 06:13+0000\n"
-"PO-Revision-Date: 2023-09-28 08:23+0000\n"
+"PO-Revision-Date: 2023-10-07 03:23+0000\n"
 "Last-Translator: Zuochenwei <zuochenwei5 at gmail.com>\n"
 "Language-Team: Chinese (Simplified) <https://weblate.osgeo.org/projects/"
 "postgis/postgis-manual/zh_Hans/>\n"
@@ -12703,7 +12703,7 @@ msgstr ", <xref linkend=\"ST_NDims\"/>, <xref linkend=\"ST_Dimension\"/>"
 #. Tag: refpurpose
 #, no-c-format
 msgid "Checks if a geometry has a Z dimension."
-msgstr ""
+msgstr "检查几何体是否具有 Z 维度。"
 #. Tag: para
 #, no-c-format
@@ -12711,31 +12711,33 @@ msgid ""
 "Checks if the input geometry has a Z dimension and returns a boolean value. "
 "If the geometry has a Z dimension, it returns true; otherwise, it returns "
 "false."
-msgstr ""
+msgstr "检查输入几何体是否具有 Z维度并返回布尔值。 如果几何体有 Z 维度,则返回 true;"
+" 否则,返回 false。"
 #. Tag: para
 #, no-c-format
 msgid ""
 "Geometry objects with a Z dimension typically represent three-dimensional "
 "(3D) geometries, while those without it are two-dimensional (2D) geometries."
-msgstr ""
+msgstr "具有 Z 维度的几何对象通常表示三维 (3D) 几何图形,而没有 Z "
+"维度的几何对象则表示二维 (2D) 几何图形。"
 #. Tag: para
 #, no-c-format
 msgid ""
 "This function is useful for determining if a geometry has elevation or "
 "height information."
-msgstr ""
+msgstr "此函数对于确定几何图形是否具有高程或高度信息非常有用。"
 #. Tag: para
 #, no-c-format
 msgid "Availability: 3.5.0"
-msgstr ""
+msgstr "可用性:3.5.0"
 #. Tag: refpurpose
 #, no-c-format
 msgid "Checks if a geometry has an M (measure) dimension."
-msgstr ""
+msgstr "检查几何体是否具有 M(测量)维度。"
 #. Tag: para
 #, no-c-format
@@ -12743,21 +12745,22 @@ msgid ""
 "Checks if the input geometry has an M (measure) dimension and returns a "
 "boolean value. If the geometry has an M dimension, it returns true; "
 "otherwise, it returns false."
-msgstr ""
+msgstr "检查输入几何图形是否具有 M(度量)维度并返回布尔值。 如果几何体具有 M 维度,"
+"则返回 true; 否则,返回 false。"
 #. Tag: para
 #, no-c-format
 msgid ""
 "Geometry objects with an M dimension typically represent measurements or "
 "additional data associated with spatial features."
-msgstr ""
+msgstr "具有 M 维度的几何对象通常表示与空间特征相关的测量值或附加数据。"
 #. Tag: para
 #, no-c-format
 msgid ""
 "This function is useful for determining if a geometry includes measure "
 "information."
-msgstr ""
+msgstr "此函数对于确定几何图形是否包含测量信息非常有用。"
 #. Tag: title
 #, no-c-format
@@ -34805,6 +34808,9 @@ msgid ""
 "kind of issues where a distance of a centimeter you want to just consider as "
 "intersecting, use <xref linkend=\"ST_3DDWithin\"/>."
 msgstr ""
+"由于浮点数精度问题,几何处理后,几何体不会总是像您期望的那样相交。例如,到几"
+"何体上的线串的最近点可能不位于线串上。对于这种情况,如果您希望将一厘米的距离"
+"视为相交,可以使用<xref linkend=\"ST_3DDWithin\"/> 函数。"
 #. Tag: para
 #, no-c-format
@@ -34819,7 +34825,7 @@ msgstr "TIN示例"
 #. Tag: para
 #, no-c-format
 msgid ", <xref linkend=\"ST_Intersects\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"ST_Intersects\"/>"
 #. Tag: refpurpose
 #, no-c-format
Summary of changes:
 doc/po/zh_Hans/postgis-manual.po | 28 +++++++++++++++++-----------
 1 file changed, 17 insertions(+), 11 deletions(-)
hooks/post-receive
