[PostGIS] #5567: Mark PostGIS extensions as trusted ( PG13+ )
PostGIS trac at osgeo.org
Fri Oct 27 01:47:34 PDT 2023
  Reporter:  strk         |      Owner:  strk
      Type:  enhancement  |     Status:  new
  Priority:  medium       |  Milestone:  PostGIS 3.5.0
 Component:  postgis      |    Version:  master
Resolution:               |   Keywords:
Comment (by Sandro Santilli <strk@…>):
 In [changeset:"5739cacd977d4917805a4485fa5f6b38dfce4d9a/git"
 5739cacd/git]:
 {{{#!CommitTicketReference repository="git"
 revision="5739cacd977d4917805a4485fa5f6b38dfce4d9a"
 run_test.pl: add POSTGIS_REGRESS_DB_OWNER env support
 Allows specifying a DB role to be given ownership of the regress
 database and be used to create extension of POSTGIS_REGRESS_EXT_CREATOR
 is not also provided to override that.
 References #5212
 References #5566
 References #5567
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5567#comment:3>
