[postgis-tickets] [PostGIS] #5569: postgis_restore doesn't strip some old functions
PostGIS trac at osgeo.org
Mon Oct 16 06:06:04 PDT 2023
  Reporter:  kesar                  |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  low                    |  Milestone:  PostGIS 3.4.1
 Component:  build/upgrade/install  |    Version:  3.4.x
Resolution:                         |   Keywords:  postgis_restore
Comment (by kesar):
 Hi & thank you!
 OK, I added a sanitized version of the manifest output as an attachment.
 The version of ''postgis_restore'' we are using is installed from
 Postgresql.org RHEL8 pgdg13-repository's package ''postgis34_13''
 $ dnf info 'postgis34_13' | grep Source
 Source       : postgis34_13-3.4.0-1PGDG.rhel8.src.rpm
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5569#comment:4>
