[postgis-tickets] [PostGIS] #5569: postgis_restore doesn't strip some old functions
PostGIS trac at osgeo.org
Tue Oct 17 03:16:47 PDT 2023
  Reporter:  kesar                  |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  low                    |  Milestone:  PostGIS 3.4.1
 Component:  build/upgrade/install  |    Version:  3.4.x
Resolution:                         |   Keywords:  postgis_restore
Comment (by strk):
 Looking at the generated DATA section in postgis_restore.pl, and focusing
 to a single signature, we have:
 In manifest:
 > 6714; 0 0 COMMENT public FUNCTION st_asgeojson(gj_version integer, geog
 geography, maxdecimaldigits integer, options integer) postgres
 > 1019; 1255 304728 FUNCTION public st_asgeojson(integer, geography,
 integer, integer) postgres
 In skip list:
 > COMMENT FUNCTION st_asgeojson(version integer, geog geography,
 > FUNCTION st_asgeojson(integer, geography, integer, integer)
 Sounds like our upgrade procedure is getting some parameter names wrong
 kesar: are you able by any chance to provide also a schema-only dump for
 us to test restoring ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5569#comment:5>
