[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-684-gb0dedd364
Mon Oct 16 21:23:49 PDT 2023
the project "PostGIS".
       via  b0dedd364ef949b86651a965c7cc69cfcbd0fddd (commit)
      from  2ec0bc0b56e6346f681c6eda2833c7c019d1ecff (commit)
revisions in full, below.
commit b0dedd364ef949b86651a965c7cc69cfcbd0fddd
Author: Wang Dapeng <wangdapeng20191008 at gmail.com>
Date:   Tue Oct 17 02:34:08 2023 +0000
    Translated PostGIS Manual using Weblate (Chinese (Simplified))
    Currently translated at 100.0% (5605 of 5605 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/zh_Hans/
diff --git a/doc/po/zh_Hans/postgis-manual.po b/doc/po/zh_Hans/postgis-manual.po
index 28a768f0a..b453999dc 100644
--- a/doc/po/zh_Hans/postgis-manual.po
+++ b/doc/po/zh_Hans/postgis-manual.po
@@ -6,7 +6,7 @@ msgstr ""
 "Project-Id-Version: postgis 3.5\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2023-10-06 06:13+0000\n"
-"PO-Revision-Date: 2023-10-16 10:23+0000\n"
+"PO-Revision-Date: 2023-10-17 04:23+0000\n"
 "Last-Translator: Wang Dapeng <wangdapeng20191008 at gmail.com>\n"
 "Language-Team: Chinese (Simplified) <https://weblate.osgeo.org/projects/"
 "postgis/postgis-manual/zh_Hans/>\n"
@@ -40037,12 +40037,12 @@ msgid ""
 "longitude and latitude. SRID 0 represents an infinite Cartesian plane with "
 "no units assigned to its axes. See <xref linkend=\"spatial_ref_sys\"/>."
 msgstr ""
-"几何值与 <emphasis role=\"bold\">空间参考系统</emphasis>指示它所嵌入的坐标"
-"系。空间参考系由几何SRID编号标识。X轴和Y轴的单位由空间参考系确定。<emphasis "
-"role=\"bold\">平面</emphasis>参考系X和Y坐标通常表示东距和北距,而在 "
-"<emphasis role=\"bold\">大地测量</emphasis>系统中,它们代表经度和纬度。SRID 0"
-"表示没有为其轴指定单位的无限笛卡尔平面。请参见<xref linkend=\"spatial_ref_sys"
+"几何值与 <emphasis role=\"bold\">空间参考系统</emphasis>指示它所嵌入的坐标系"
+"。空间参考系由几何SRID编号标识。X轴和Y轴的单位由空间参考系确定。<emphasis "
+"role=\"bold\">平面</emphasis>参考系统中,X 和 Y 坐标通常表示东向和北向,而在 "
+"<emphasis role=\"bold\">大地测量</emphasis>测量系统中,它们表示经度和纬度。"
+"SRID 0 表示一个具有无单位的无限笛卡尔平面。请参见<xref linkend="
+"\"spatial_ref_sys\"/>。"
 #. Tag: para
 #, no-c-format
@@ -40062,8 +40062,8 @@ msgid ""
 "values contain no vertices (for atomic geometry types) or no elements (for "
 "collections)."
 msgstr ""
-"几何值可能为 <emphasis role=\"bold\">空</emphasis>。空值不包含折点(对于原子"
-"几何类型)或无元素(对于集合)。"
+"几何值可以为 <emphasis role=\"bold\""
+">空</emphasis>。空值不包含顶点(对于原子几何类型)或不包含元素(对于集合)。"
 #. Tag: para
 #, no-c-format
@@ -40107,10 +40107,11 @@ msgid ""
 "storing and manipulating invalid geometry values. This allows detecting and "
 "fixing them if needed. See <xref linkend=\"OGC_Validity\"/>"
 msgstr ""
-"OGC几何模型定义了每种几何类型的有效性规则。这些规则确保几何值代表现实情况(例"
-"如,可以指定一个带有位于壳外的孔的多边形,但这在几何上没有意义,因此是无效"
-"的)。PostGIS 还允许存储和操作无效的几何值。这允许在需要时检测并修复它们。请"
-"参阅<xref linkend=\"OGC_Validity\"/>"
+"OGC几何模型为每种几何类型定义了有效性规则。这些规则确保几何值表示现实情况(例"
+"如,可以指定一个具有孔的多边形位于外壳之外,但从几何角度来看这是没有意义的,"
+"因此是无效的)。PostGIS "
+"也允许存储和操作无效的几何值。这允许在需要时检测和修复它们。请参阅<xref "
+"linkend=\"OGC_Validity\"/>"
 #. Tag: title
 #, no-c-format
Summary of changes:
 doc/po/zh_Hans/postgis-manual.po | 27 ++++++++++++++-------------
 1 file changed, 14 insertions(+), 13 deletions(-)
hooks/post-receive
