[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-685-g469361aaa
Tue Oct 17 01:23:49 PDT 2023
the project "PostGIS".
       via  469361aaaa0d17ee27ea463de4ce85b7a881276f (commit)
      from  b0dedd364ef949b86651a965c7cc69cfcbd0fddd (commit)
revisions in full, below.
commit 469361aaaa0d17ee27ea463de4ce85b7a881276f
Author: Wang Dapeng <wangdapeng20191008 at gmail.com>
Date:   Tue Oct 17 06:47:50 2023 +0000
    Translated PostGIS Manual using Weblate (Chinese (Simplified))
    Currently translated at 100.0% (5605 of 5605 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/zh_Hans/
diff --git a/doc/po/zh_Hans/postgis-manual.po b/doc/po/zh_Hans/postgis-manual.po
index b453999dc..851bc378f 100644
--- a/doc/po/zh_Hans/postgis-manual.po
+++ b/doc/po/zh_Hans/postgis-manual.po
@@ -6,7 +6,7 @@ msgstr ""
 "Project-Id-Version: postgis 3.5\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2023-10-06 06:13+0000\n"
-"PO-Revision-Date: 2023-10-17 04:23+0000\n"
+"PO-Revision-Date: 2023-10-17 08:23+0000\n"
 "Last-Translator: Wang Dapeng <wangdapeng20191008 at gmail.com>\n"
 "Language-Team: Chinese (Simplified) <https://weblate.osgeo.org/projects/"
 "postgis/postgis-manual/zh_Hans/>\n"
@@ -5733,7 +5733,7 @@ msgstr "如果tolerance = 0,则该函数使用 ST_Intersects,否则使用 ST
 #. Tag: para
 #, no-c-format
 msgid "Performed by the GEOS module."
-msgstr "它是通过GEOS模块实现的。"
+msgstr "这个函数是由 GEOS 模块执行的。"
 #. Tag: para
 #, no-c-format
@@ -25876,10 +25876,10 @@ msgid ""
 "simplification occurs on a object-by-object basis you can also feed a "
 "GeometryCollection to this function."
 msgstr ""
-"使用 Douglas-Peucker 算法返回给定几何图形的“简化”版本。 实际上只会对(多)线"
-"和(多)多边形执行某些操作,但您可以使用任何类型的几何体安全地调用它。 由于简"
-"化是在逐个对象的基础上进行的,因此您还可以将 GeometryCollection 提供给此函"
-"数。"
+"使用 Douglas-Peucker 算法返回给定几何图形的“简化”版本的函数。这个函数的目标是"
+"避免创建无效的派生几何(尤其是多边形)。通常,这个函数会用于(多)线和(多)多边"
+"形,但你也可以安全地将任何类型的几何图形传递给它。由于简化是以对象为单位进行"
+"的,因此你还可以将 GeometryCollection(几何对象的集合)传递给此函数。"
 #. Tag: para
 #, no-c-format
@@ -25891,10 +25891,10 @@ msgid ""
 "engines, to avoid having large numbers of very small objects disappear from "
 "a map leaving surprising gaps."
 msgstr ""
-"“保留折叠”标志将保留在给定容差的情况下太小的对象。 例如,将 1m 长的线简化为 "
-"10m 公差。 如果将<varname> preserveCollapsed </varname>参数指定为 true,则该"
-"线不会消失。 该标志对于渲染引擎很有用,可以避免大量非常小的对象从地图上消失,"
-"留下令人惊讶的间隙。"
+"\"保留已折叠\" 标志将保留在给定容差下本来会被认为太小而被删除的对象。例如,"
+"使用 10 米的容差对 1 米长的线进行简化。如果指定了 "
+"<varname>preserveCollapsed</varname> 参数为 true,则该线将不会消失。这个标志"
+"对于渲染引擎非常有用,以避免在地图上有大量非常小的对象消失,留下意外的空隙。"
 #. Tag: para
 #, no-c-format
Summary of changes:
 doc/po/zh_Hans/postgis-manual.po | 20 ++++++++++----------
 1 file changed, 10 insertions(+), 10 deletions(-)
hooks/post-receive
