[postgis-tickets] [PostGIS] #5341: debbie failing on raster upgrade from 3.2, 3.1 to 3.4
PostGIS trac at osgeo.org
Tue Oct 17 05:38:31 PDT 2023
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  blocker                |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:  fixed                  |   Keywords:
Comment (by Sandro Santilli <strk@…>):
 In [changeset:"194b27a856b63a7b7ad8a8353788b5480b5cc51c/git" 194b27a/git]:
 {{{#!CommitTicketReference repository="git"
 revision="194b27a856b63a7b7ad8a8353788b5480b5cc51c"
 Enable upgrade-from-unpackaged tests by default, allow disabling
 Pass --skip-unpackaged to skip those tests
 References #5573
 References #5341
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5341#comment:24>
