[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-688-g5e8783b89
Tue Oct 17 05:56:30 PDT 2023
the project "PostGIS".
       via  5e8783b89cb989c06e9b57a1ecf85a905c05f23e (commit)
      from  194b27a856b63a7b7ad8a8353788b5480b5cc51c (commit)
revisions in full, below.
commit 5e8783b89cb989c06e9b57a1ecf85a905c05f23e
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Oct 17 14:56:14 2023 +0200
    run_test.pl: make a guess at where build tree may be
diff --git a/regress/run_test.pl b/regress/run_test.pl
index 6424a2bdc..11d0dabf6 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -51,7 +51,7 @@ our $DB = $ENV{"POSTGIS_REGRESS_DB"} || "postgis_reg";
 our $REGDIR = $ENV{"POSTGIS_REGRESS_DIR"} || abs_path(dirname($0));
 our $TOP_SOURCEDIR = ${REGDIR} . '/..';
 our $ABS_TOP_SOURCEDIR = abs_path(${TOP_SOURCEDIR});
-our $TOP_BUILDDIR = $ENV{"POSTGIS_TOP_BUILD_DIR"} || ${TOP_SOURCEDIR};
+our $TOP_BUILDDIR = $ENV{"POSTGIS_TOP_BUILD_DIR"};
 our $sysdiff = !system("diff --strip-trailing-cr $0 $0 2> /dev/null");
@@ -148,6 +148,20 @@ sub findOrDie
     die "HINT: use POSTGIS_TOP_BUILD_DIR env or --build-dir switch the specify top build dir.\n";
+# If build dir is not given, try to guess
+if ( "${TOP_BUILDDIR}" eq "" )
+    foreach my $d ( $ENV{'PWD'}, "${TOP_SOURCEDIR}" )
+        if ( -e ${d} . '/postgis_revision.h' )
+            $TOP_BUILDDIR="${d}";
+            last;
 # Prepend scripts' build dirs to path
 # TODO: make this conditional ?
 $ENV{PATH} = $TOP_BUILDDIR . '/loader:' .
Summary of changes:
 regress/run_test.pl | 16 +++++++++++++++-
 1 file changed, 15 insertions(+), 1 deletion(-)
hooks/post-receive
