[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-689-g20a22b1a6
Tue Oct 17 06:13:09 PDT 2023
the project "PostGIS".
       via  20a22b1a63fdd2ed062872cfceda23ca6bc339c3 (commit)
      from  5e8783b89cb989c06e9b57a1ecf85a905c05f23e (commit)
revisions in full, below.
commit 20a22b1a63fdd2ed062872cfceda23ca6bc339c3
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Oct 17 15:12:59 2023 +0200
    Update regress/README
diff --git a/regress/README b/regress/README
index 093d1dd14..7e29fd909 100644
--- a/regress/README
+++ b/regress/README
@@ -3,81 +3,35 @@ Requirements for run_test.pl
 run_test.pl requires the following Perl modules to be installed
- Text::Diff;
- File::Which;
- File::Basename;
- File::Temp 'tempdir';
- File::Copy;
- File::Path 'make_path';
- File::Path 'remove_tree';
- Cwd 'abs_path';
- Getopt::Long;
+ File::Basename
+ Time::HiRes
+ File::Temp
+ File::Copy
+ File::Path
+ Cwd
+ Getopt::Long
-Most distributions of Perl will have everything except Text::Diff and File::Which.
-To install them from the command-line, as root run
- cpan Text::Diff
- cpan File::Which
+Most distributions of Perl will have everything
 How to add a regression test
-1. Write a /regress/<testname>.sql file with data and sql queries for testing
-2. Write a /regress/<testname>_expected or <testname>_expected.in file with
-   expected results per query
-   The expected results provided in the <testname>_expected file must be
-   formatted using the following psql options:
-      -a -- unaligned columns
-      -f | -- use | (pipe) as the field separator between columns
-      -t -- output rows only, ie. no table header
+1. Write a ${test}.sql file with test sql queries
-   cat file.sql | psql -F\| -t -A > file_expected
+2. Generate and tweak ${test}_expected file:
+   regress/run_test.pl --expect ${test} && vi ${test}_expected
-3. Edit regress/Makefile adding <testname> to the TESTS variable.
-   Any _expected.in files need to be added to the PREPROC variable.
+3. Add ${test} to $(dirname ${test})/tests.mk*
 Optional:
    If your test has unusual setup or teardown requirements, you may create
    any of the following optional files (they will run in this order):
-        /regress/<testname>-pre.sh
-        /regress/<testname>-pre.sql   (run via psql)
+        ${test}-pre.sh
+        ${test}-pre.sql   (run via psql)
                  (The test itself is run here.)
-        /regress/<testname>-post.sql  (run via psql)
-        /regress/<testname>-post.sh
-Notes about changes in regression tests introduces with PostGIS 1.1.0
-- Mixed-dimensioned geometries are no longer supported
-  (previous behaviour was to fill Z with a 0 value)
-  [ updated to use new behaviour ]
-- geometry_same operator (=~) now requires all dimensions equality
-  Previously only x/y were checked
-- geometry_same operator (=~) now requires geom type equality
-  Previous behaviour:
-     GEOMETRYCOLLECTION(POINT(0 1), POINT(2 3)) =~  MULTIPOINT(0 1,2 3)
-- numb_sub_geometries does not exist anymore
-  [updated to use numgeometries]
-- truly_inside does not exist anymore
-  [updated to use within]
-Notes about <testname>_expected.in
-The first line of the <testname>_expected.in should include the postgis
-configuration header.
-  #include "../postgis_config.h"
-The ability to run a c preprocessor over the expected results prior to
-regression testing was needed for testing curved string functionality that
-would elicit different responses from JTS vs GEOS compilations.  Since
-JTS is no longer supported, this may not be required anymore.
+        ${test}-post.sql  (run via psql)
+        ${test}-post.sh
 Notes about running individual regression tests
Summary of changes:
 regress/README | 78 ++++++++++++----------------------------------------------
 1 file changed, 16 insertions(+), 62 deletions(-)
hooks/post-receive
