[postgis-tickets] [SCM] PostGIS branch stable-3.4 updated. 3.4.0-37-g9c44d61fd
Tue Oct 17 13:50:56 PDT 2023
the project "PostGIS".
The branch, stable-3.4 has been updated
       via  9c44d61fdcb9c8ef54c82ee6e15a29df985cadf9 (commit)
       via  569c54eb4f99808b5b964e49b2142fcaed850701 (commit)
       via  760f34e152867c847ec8b7aec42e2ed78c547678 (commit)
       via  13a4201c6dbb96259b293f7b7cde0775783900bb (commit)
      from  b328e7452793eec40978f61e65d5c47d0198bc6e (commit)
revisions in full, below.
commit 9c44d61fdcb9c8ef54c82ee6e15a29df985cadf9
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Oct 17 22:39:17 2023 +0200
    Fix restore of dumps with topology from 3.1
    Closes #5577 in 3.4 branch (3.4.1dev)
diff --git a/NEWS b/NEWS
index 546e4d82f..9d02a0a8a 100644
--- a/NEWS
+++ b/NEWS
@@ -7,7 +7,7 @@ To take advantage of all SFCGAL featurs, SFCGAL 1.4.1+ is needed.
 * Bug Fixes *
- - #5574, #5575, #5576, Fix restore of postgis dumps from 3.0 (Sandro Santilli)
+ - #5574, #5575, #5576, #5577, Fix restore of postgis dumps (Sandro Santilli)
  - #5568, Improve robustness of topology face split handling (Sandro Santilli)
  - #5548, Fix box-filtered validity check of topologies with edge-less faces
           (Sandro Santilli)
diff --git a/topology/topology_before_upgrade.sql.in b/topology/topology_before_upgrade.sql.in
index aa0c7252f..bf4104c0d 100644
--- a/topology/topology_before_upgrade.sql.in
+++ b/topology/topology_before_upgrade.sql.in
@@ -13,34 +13,20 @@
 -- argument names changed --
 -- we might want to take toTopoGeom one out before release since
 -- I don't think too many people installed the bad name
-SELECT NULL FROM _postgis_drop_function_by_signature('
-topology.toTopoGeom(Geometry, varchar, int, float8)
+SELECT _postgis_drop_function_by_signature('topology.toTopoGeom(Geometry, varchar, int, float8)');
 -- used to be in public, will now be moved to topology
-public.postgis_topology_scripts_installed()
+SELECT _postgis_drop_function_by_signature('public.postgis_topology_scripts_installed()');
 -- Removed in 2.2.0 when topology API moved to liblwgeom
-topology._ST_RemEdgeCheck(varchar, integer, integer, integer, integer)
-', '2.2.0');
+SELECT _postgis_drop_function_by_signature('topology._ST_RemEdgeCheck(varchar, integer, integer, integer, integer)', '2.2.0');
-topology._ST_AddFaceSplit(varchar, integer, integer, boolean)
-', '2.2.0');
+SELECT _postgis_drop_function_by_signature('topology._ST_AddFaceSplit(varchar, integer, integer, boolean)', '2.2.0');
 -- Added optional bbox parameter in 3.2.0
-topology.validatetopology(varchar)
-', '3.2.0');
+SELECT _postgis_drop_function_by_signature('topology.validatetopology(varchar)', '3.2.0');
 -- Merged the two function into one with both allowEdgeSplitting and setContainingFace parameters
 -- being optional (3.2.0)
-topology.AddNode(varchar, geometry)
-', '3.2.0');
-topology.AddNode(varchar, geometry, boolean, boolean)
-', '3.2.0');
+SELECT _postgis_drop_function_by_signature('topology.AddNode(varchar, geometry)', '3.2.0');
+SELECT _postgis_drop_function_by_signature('topology.AddNode(varchar, geometry, boolean, boolean)', '3.2.0');
diff --git a/utils/create_skip_signatures.pl b/utils/create_skip_signatures.pl
index 9995d4127..7d67fda0a 100644
--- a/utils/create_skip_signatures.pl
+++ b/utils/create_skip_signatures.pl
@@ -205,12 +205,12 @@ while (<>)
 	# Deprecated function signature using
 	# _postgis_drop_function_by_signature
 	# EXAMPLE: SELECT _postgis_drop_function_by_signature('pgis_geometry_union_finalfn(internal)');
-	elsif ( /SELECT _postgis_drop_function_by_signature\('[^']*'\);/ )
+	elsif ( /SELECT _postgis_drop_function_by_signature\('[^']*'/ )
 		my $origline = $_;
 		my $line = $origline;
-		$line =~ s/SELECT _postgis_drop_function_by_signature\('([^']*)'\);/$1/;
+		$line =~ s/.*SELECT _postgis_drop_function_by_signature\('([^']*)'.*/$1/;
 		handle_function_signature($line);
commit 569c54eb4f99808b5b964e49b2142fcaed850701
Date:   Tue Oct 17 21:57:06 2023 +0200
    Do not print info messages on stderr unless -v is given
diff --git a/utils/postgis_restore.pl.in b/utils/postgis_restore.pl.in
index a99a3d23f..e4115a77e 100644
--- a/utils/postgis_restore.pl.in
+++ b/utils/postgis_restore.pl.in
@@ -92,7 +92,8 @@ die "$me:\tUnable to find 'pg_dump' on the path.\n" if ! `pg_dump --version`;
 die "$me:\tUnable to find 'pg_restore' on the path.\n" if ! `pg_restore --version`;
 die "$me:\tUnable to open dump file '$dumpfile'.\n" if ! -r $dumpfile;
-print STDERR "Converting $dumpfile to ASCII on stdout...\n";
+print STDERR "Converting $dumpfile to ASCII on stdout...\n"
+  if $DEBUG;
 STDOUT->autoflush(1);
@@ -100,7 +101,8 @@ STDOUT->autoflush(1);
 # Load the signatures of things to skip.
-print STDERR "  Reading list of functions to ignore...\n";
+print STDERR "  Reading list of functions to ignore...\n"
+  if $DEBUG;
 my %skip = ();
 while(my $l = <DATA>) {
@@ -116,7 +118,8 @@ while(my $l = <DATA>) {
 if(!defined($POSTGIS_TOC)) {
-  print STDERR "  Writing manifest of things to read from dump file...\n";
+  print STDERR "  Writing manifest of things to read from dump file...\n"
+    if $DEBUG;
   open( DUMP, "pg_restore -f - -l $dumpfile |" ) || die "$me:\tCannot open dump file '$dumpfile'\n";
 } else {
@@ -135,7 +138,8 @@ while( my $l = <DUMP> ) {
 		if ( $l =~ / TABLE DATA ([^ ]*) spatial_ref_sys / )
 			$POSTGIS_SCHEMA = $1;
-			print STDERR "Setting postgis schema to $POSTGIS_SCHEMA, as found in the dump";
+			print STDERR "  Setting postgis schema to $POSTGIS_SCHEMA, as found in the dump\n"
+			  if $DEBUG;
@@ -154,7 +158,8 @@ close(DUMP) || die "$me: pg_restore returned an error\n";
 # Convert the dump file into an ASCII file, stripping out the
 # unwanted bits.
-print STDERR "  Writing ASCII to stdout...\n";
+print STDERR "  Writing ASCII to stdout...\n"
+  if $DEBUG;
 open( INPUT, "pg_restore -f - -L $manifest $dumpfile |") || die "$me:\tCan't run pg_restore\n";
 if ( defined $POSTGIS_SCHEMA ) {
commit 760f34e152867c847ec8b7aec42e2ed78c547678
Date:   Tue Oct 17 20:53:36 2023 +0200
    Fix `\1 better written as $1` perl warnings
index 32a571a1f..9995d4127 100644
@@ -197,7 +197,7 @@ while (<>)
 		my $origline = $_;
-		$line =~ s/ *ALTER FUNCTION (.*) RENAME TO .*_deprecated_by_postgis_.*/\1/;
+		$line =~ s/ *ALTER FUNCTION (.*) RENAME TO .*_deprecated_by_postgis_.*/$1/;
@@ -210,7 +210,7 @@ while (<>)
 		my $origline = $_;
-		$line =~ s/SELECT _postgis_drop_function_by_signature\('([^']*)'\);/\1/;
+		$line =~ s/SELECT _postgis_drop_function_by_signature\('([^']*)'\);/$1/;
commit 13a4201c6dbb96259b293f7b7cde0775783900bb
Date:   Tue Oct 17 20:54:01 2023 +0200
    Remove needlessly hard-coded skip signatures
    See https://woodie.osgeo.org/repos/30/pipeline/1323/7#L2093
index 1f1b8f64e..a99a3d23f 100644
@@ -563,7 +563,6 @@ COMMENT FUNCTION addrasterconstraints(rasttable name, rastcolumn name, VARIADIC
 COMMENT FUNCTION droprasterconstraints(rastschema name, rasttable name, rastcolumn name, VARIADIC constraints text[])
 COMMENT FUNCTION lockrow(text, text, text, text, timestamp without time zone)
 COMMENT FUNCTION lockrow(text, text, text, timestamp without time zone)
-COMMENT FUNCTION postgis_extensions_upgrade()
 COMMENT FUNCTION st_clusterkmeans(geom geometry, k integer)
 COMMENT FUNCTION st_concavehull(param_geom geometry, param_pctconvex double precision, param_allow_holes boolean)
 COMMENT FUNCTION st_difference(geom1 geometry, geom2 geometry)
@@ -615,7 +614,6 @@ COMMENT FUNCTION st_subdivide(geom geometry, maxvertices integer)
 COMMENT FUNCTION st_sum4ma(matrix double precision[], nodatamode text, VARIADIC args text[])
 COMMENT FUNCTION st_sum4ma(value double precision[], pos integer[], VARIADIC userargs text[])
 COMMENT FUNCTION st_symdifference(geom1 geometry, geom2 geometry)
-COMMENT FUNCTION st_unaryunion(geometry)
 COMMENT FUNCTION st_valuecount(rastertable text, rastercolumn text, nband integer, exclude_nodata_value boolean, searchvalues double precision[], roundto double precision, OUT value double precision, OUT count integer)
 COMMENT FUNCTION st_valuecount(rastertable text, rastercolumn text, nband integer, searchvalues double precision[], roundto double precision, OUT value double precision, OUT count integer)
 COMMENT FUNCTION st_valuecount(rastertable text, rastercolumn text, searchvalues double precision[], roundto double precision, OUT value double precision, OUT count integer)
@@ -638,21 +636,13 @@ FUNCTION jsonb(geometry)
 FUNCTION json(geometry)
-FUNCTION postgis_extensions_upgrade()
 FUNCTION _st_aspect4ma(double precision[], integer[], text[])
-FUNCTION st_clusterkmeans(geometry, integer)
 FUNCTION st_concavehull(geometry, double precision, boolean)
 FUNCTION _st_convertarray4ma(double precision[])
-FUNCTION st_difference(geometry, geometry)
 FUNCTION st_distinct4ma(double precision[], integer[], text[])
 FUNCTION st_distinct4ma(double precision[], text, text[])
-FUNCTION st_force3d(geometry)
-FUNCTION st_force3dm(geometry)
-FUNCTION st_force3dz(geometry)
-FUNCTION st_force4d(geometry)
 FUNCTION _st_grayscale4ma(double precision[], integer[], text[])
 FUNCTION _st_hillshade4ma(double precision[], integer[], text[])
-FUNCTION st_intersection(geometry, geometry)
 FUNCTION st_invdistweight4ma(double precision[], integer[], text[])
 FUNCTION _st_mapalgebra(rastbandarg[], regprocedure, text, integer, integer, text, raster, double precision[], boolean, text[])
 FUNCTION st_mapalgebra(raster, integer, regprocedure, double precision[], boolean, text, text, raster, text[])
@@ -673,14 +663,10 @@ FUNCTION st_setvalues(raster, integer, integer, integer, double precision[], dou
 FUNCTION _st_slope4ma(double precision[], integer[], text[])
 FUNCTION st_stddev4ma(double precision[], integer[], text[])
 FUNCTION st_stddev4ma(double precision[], text, text[])
-FUNCTION st_subdivide(geometry, integer)
 FUNCTION st_sum4ma(double precision[], integer[], text[])
 FUNCTION st_sum4ma(double precision[], text, text[])
-FUNCTION st_symdifference(geometry, geometry)
-FUNCTION st_tileenvelope(integer, integer, integer, geometry)
 FUNCTION _st_tpi4ma(double precision[], integer[], text[])
 FUNCTION _st_tri4ma(double precision[], integer[], text[])
-FUNCTION st_unaryunion(geometry)
 OPERATOR &&
 OPERATOR &&&
 OPERATOR &/&
Summary of changes:
 NEWS                                    |  2 +-
 topology/topology_before_upgrade.sql.in | 28 +++++++---------------------
 utils/create_skip_signatures.pl         |  6 +++---
 utils/postgis_restore.pl.in             | 29 ++++++++++-------------------
 4 files changed, 21 insertions(+), 44 deletions(-)
hooks/post-receive
