[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-696-g5a8528e77
Tue Oct 17 14:07:28 PDT 2023
the project "PostGIS".
       via  5a8528e775d15538898d6483c81052ca1df72607 (commit)
      from  cc1607004b6b6ff6437b1e9a7708e1198c74af88 (commit)
revisions in full, below.
commit 5a8528e775d15538898d6483c81052ca1df72607
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Oct 17 23:06:54 2023 +0200
    Propery drop st_approxquantile signatures deprecated in 3.1
    References #5578 in master branch (3.5.0dev)
diff --git a/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in b/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in
index 4eb95a95e..3f7ed38b7 100644
--- a/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in
+++ b/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in
@@ -287,13 +287,19 @@ SELECT _postgis_drop_function_by_signature('st_approxquantile(raster, double pre
 SELECT _postgis_drop_function_by_signature('st_quantile(text, text, int, boolean, double precision[])');
 SELECT _postgis_drop_function_by_signature('st_quantile(text, text, int, double precision[])');
 SELECT _postgis_drop_function_by_signature('st_quantile(text, text, double precision[])');
+SELECT _postgis_drop_function_by_signature('st_approxquantile(text, text, double precision)', '3.1.0'); -- See https://trac.osgeo.org/postgis/ticket/5578
+SELECT _postgis_drop_function_by_signature('st_approxquantile(text, text, boolean, double precision)', '3.1.0'); -- See https://trac.osgeo.org/postgis/ticket/5578
+SELECT _postgis_drop_function_by_signature('st_approxquantile(text, text, double precision, double precision)', '3.1.0'); -- See https://trac.osgeo.org/postgis/ticket/5578
+SELECT _postgis_drop_function_by_signature('st_approxquantile(text, text, integer, double precision, double precision)', '3.1.0'); -- See https://trac.osgeo.org/postgis/ticket/5578
+SELECT _postgis_drop_function_by_signature('st_approxquantile(text, text, integer, boolean, double precision, double precision)', '3.1.0'); -- See https://trac.osgeo.org/postgis/ticket/5578
 SELECT _postgis_drop_function_by_signature('st_approxquantile(text, text, int, boolean, double precision, double precision[])');
 SELECT _postgis_drop_function_by_signature('st_approxquantile(text, text, int, double precision, double precision[])');
 SELECT _postgis_drop_function_by_signature('st_approxquantile(text, text, double precision, double precision[])');
 SELECT _postgis_drop_function_by_signature('st_approxquantile(text, text, double precision[])');
 SELECT _postgis_drop_function_by_signature('_st_quantile(raster, int, boolean, double precision, double precision[])');
 SELECT _postgis_drop_function_by_signature('_st_quantile(text, text, int, boolean, double precision, double precision[])');
--- this cannot be drop until the quantile deprecated functions are gon
+-- this cannot be drop until the quantile deprecated functions are gone
 DROP TYPE IF EXISTS quantile;
 -- remove TYPE valuecount
Summary of changes:
 raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in | 8 +++++++-
 1 file changed, 7 insertions(+), 1 deletion(-)
hooks/post-receive
