[postgis-tickets] [PostGIS] #5579: restoring dump from 3.0: ERROR: function "st_quantile" already exists with same argument types
PostGIS trac at osgeo.org
Tue Oct 17 14:10:15 PDT 2023
same argument types
 Reporter:  strk                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  medium                 |  Milestone:  PostGIS 3.4.1
Component:  build/upgrade/install  |    Version:  3.4.x
 Keywords:  raster                 |
 regress/run_test.pl --raster --dumprestore --upgrade-path
 unpackaged3.0--:auto regress/core/regress
 Signatures in dump:
 FUNCTION public st_quantile(text, text, double precision)
 FUNCTION public st_quantile(text, text, boolean, double precision)
 FUNCTION st_quantile(rastertable text, rastercolumn text, nband integer,
 quantiles double precision[], OUT quantile double precision, OUT value
 double precision)
 FUNCTION public st_quantile(text, text, integer, double precision)
 exclude_nodata_value boolean, quantiles double precision[], OUT quantile
 double precision, OUT value double precision)
 FUNCTION public st_quantile(text, text, integer, boolean, double
 precision)
 Signatures in generated skip list:
 FUNCTION st_quantile(raster, boolean, double precision)
 FUNCTION st_quantile(raster, double precision)
 FUNCTION st_quantile(raster, double precision[])
 FUNCTION st_quantile(raster, integer, boolean, double precision)
 FUNCTION st_quantile(raster, integer, boolean, double precision[])
 FUNCTION st_quantile(raster, integer, double precision)
 FUNCTION st_quantile(raster, integer, double precision[])
 FUNCTION st_quantile(text, text, double precision[])
 FUNCTION st_quantile(text, text, integer, boolean, double precision[])
 FUNCTION st_quantile(text, text, integer, double precision[])
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5579>
