[postgis-tickets] [PostGIS] #5573: Enable postgis_restore based upgrade tests in CI
PostGIS trac at osgeo.org
Tue Oct 17 16:00:11 PDT 2023
  Reporter:  strk       |      Owner:  robe
      Type:  task       |     Status:  new
  Priority:  medium     |  Milestone:  Website Management, Bots
 Component:  buildbots  |    Version:
Resolution:             |   Keywords:
Comment (by Sandro Santilli <strk@…>):
 In [changeset:"cda98456b0ab1785aca0ea345eecc7fff14008fd/git"
 cda98456/git]:
 {{{#!CommitTicketReference repository="git"
 revision="cda98456b0ab1785aca0ea345eecc7fff14008fd"
 Add hard-upgrade testing and --skip switch to check_all_upgrades
 You can disable hard-upgrade testing by passing `--skip hard`
 The --skip-unpackaged switch was also removed as you can now
 do the same with `--skip unpackaged`
 References #5573 in master branch
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5573#comment:8>
