[postgis-tickets] [PostGIS] #5573: Enable postgis_restore based upgrade tests in CI
PostGIS trac at osgeo.org
Tue Oct 17 16:05:36 PDT 2023
  Reporter:  strk       |      Owner:  robe
      Type:  task       |     Status:  closed
  Priority:  medium     |  Milestone:  Website Management, Bots
 Component:  buildbots  |    Version:
Resolution:  fixed      |   Keywords:
Changes (by Sandro Santilli <strk@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"e9f3ad081965136aefb78a91498ca617a541fe83/git" e9f3ad0/git]:
 {{{#!CommitTicketReference repository="git"
 revision="e9f3ad081965136aefb78a91498ca617a541fe83"
 Add hard-upgrade testing and --skip switch to check_all_upgrades
 You can disable hard-upgrade testing by passing `--skip hard`
 You can disable unpacakged upgrades by passing `--skip unpackaged`
 Closes #5573
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5573#comment:9>
