[postgis-tickets] [SCM] PostGIS branch stable-3.4 updated. 3.4.0-44-g817e9d0e3
Wed Oct 18 03:49:29 PDT 2023
the project "PostGIS".
The branch, stable-3.4 has been updated
       via  817e9d0e3cbe3f7a539f8386223bfbe1ef10dade (commit)
       via  a6fcbf27d9af238991290d76e6245009669d30ad (commit)
       via  029584e50c3808873c52d32bef0aba2490598078 (commit)
       via  e4838d9b88d51709bb76b780d4efd8d5e314e310 (commit)
      from  bc51b1a6dd813aeb1c253f23e2cee4c5a5099166 (commit)
revisions in full, below.
commit 817e9d0e3cbe3f7a539f8386223bfbe1ef10dade
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Oct 18 11:40:58 2023 +0200
    Skip shelltype when type is skipped
    Closes #5569 in 3.4 branch (3.4.1dev)
diff --git a/NEWS b/NEWS
index 83a9091eb..3446965be 100644
--- a/NEWS
+++ b/NEWS
@@ -7,8 +7,8 @@ To take advantage of all SFCGAL featurs, SFCGAL 1.4.1+ is needed.
 * Bug Fixes *
- - #5574, #5575, #5576, #5577, #5578, #5579,
-          Fix restore of postgis dumps (Sandro Santilli)
+ - #5574, #5575, #5576, #5577, #5578, #5579, #5569
+          Fix restore of postgis dumps since 2.1 (Sandro Santilli)
  - #5568, Improve robustness of topology face split handling (Sandro Santilli)
  - #5548, Fix box-filtered validity check of topologies with edge-less faces
           (Sandro Santilli)
diff --git a/utils/postgis_restore.pl.in b/utils/postgis_restore.pl.in
index a68f4a718..4fcd73fb8 100644
--- a/utils/postgis_restore.pl.in
+++ b/utils/postgis_restore.pl.in
@@ -137,6 +137,9 @@ while( my $l = <DUMP> ) {
   # always skip associated comments associated to objects,
   # see https://trac.osgeo.org/postgis/ticket/3078
   $sig =~ s/^COMMENT//g;
+  # always skip shelltype when type is skipped
+  # see https://trac.osgeo.org/postgis/ticket/5569#comment:16
+  $sig =~ s/^SHELLTYPE/TYPE/g;
   $sig =~ s/\s//g;
   $hasTopology = 1 if $sig eq 'SCHEMAtopology';
commit a6fcbf27d9af238991290d76e6245009669d30ad
Date:   Wed Oct 18 11:29:48 2023 +0200
    Drop deprecated pgis_abs based functions from <2.5 dumps
    References #5569 in 3.4 branch (3.4.1dev)
diff --git a/postgis/postgis_after_upgrade.sql b/postgis/postgis_after_upgrade.sql
index 168b9c120..7469567eb 100644
--- a/postgis/postgis_after_upgrade.sql
+++ b/postgis/postgis_after_upgrade.sql
@@ -171,9 +171,17 @@ SELECT _postgis_drop_function_by_signature('ST_AsBinary(text)'); -- deprecated i
 SELECT _postgis_drop_function_by_signature('postgis_uses_stats()'); -- deprecated in 2.0
 SELECT _postgis_drop_function_by_signature('ST_GeneratePoints(geometry, numeric)'); -- numeric -> integer
--- Old accum aggregate support type, removed in 2.5.0
--- See #4035
-DROP TYPE IF EXISTS pgis_abs CASCADE;
+-- Old accum aggregate support type, removed in 2.5.0 See #4035
+SELECT _postgis_drop_function_by_signature('pgis_abs_in(cstring)', '2.5.0');
+SELECT _postgis_drop_function_by_signature('pgis_abs_out(pgis_abs)', '2.5.0');
+SELECT _postgis_drop_function_by_signature('pgis_geometry_accum_finalfn(pgis_abs)', '2.5.0');
+SELECT _postgis_drop_function_by_signature('pgis_geometry_accum_transfn(pgis_abs, geometry)', '2.5.0');
+SELECT _postgis_drop_function_by_signature('pgis_geometry_collect_finalfn(pgis_abs)', '2.5.0');
+SELECT _postgis_drop_function_by_signature('pgis_geometry_makeline_finalfn(pgis_abs)', '2.5.0');
+SELECT _postgis_drop_function_by_signature('pgis_geometry_polygonize_finalfn(pgis_abs)', '2.5.0');
+SELECT _postgis_drop_function_by_signature('pgis_geometry_union_finalfn(pgis_abs)', '2.5.0');
+DROP TYPE IF EXISTS pgis_abs CASCADE; -- TODO: use a _postgis_drop_type ?
 SELECT _postgis_drop_function_by_signature('st_astwkb(geometry, integer, bigint, bool, bool)'); -- temporarely introduced before 2.2.0 final
 SELECT _postgis_drop_function_by_signature('pgis_twkb_accum_transfn(internal, geometry, integer)'); -- temporarely introduced before 2.2.0 final
commit 029584e50c3808873c52d32bef0aba2490598078
Date:   Wed Oct 18 12:42:01 2023 +0200
    Fix deprecation of functions taking deprecated types
diff --git a/postgis/common_before_upgrade.sql b/postgis/common_before_upgrade.sql
index 29b9f59fe..6492a5778 100644
--- a/postgis/common_before_upgrade.sql
+++ b/postgis/common_before_upgrade.sql
@@ -102,9 +102,15 @@ BEGIN
 		INTO proc;
 	EXCEPTION
-	WHEN undefined_function THEN
+	WHEN undefined_function OR undefined_object THEN
 		RAISE DEBUG 'Deprecated function % does not exist', function_signature;
 		RETURN;
+	WHEN others THEN
+		GET STACKED DIAGNOSTICS detail := PG_EXCEPTION_DETAIL;
+		RAISE WARNING 'Could not check deprecated function % existance, got % (%), assuming it does not exist',
+			function_signature, SQLERRM, SQLSTATE
+		USING DETAIL = detail;
+		RETURN;
 	END;
 	sql := pg_catalog.format(
commit e4838d9b88d51709bb76b780d4efd8d5e314e310
Date:   Wed Oct 18 11:41:19 2023 +0200
    Don't bother checking empty lines
index 5ccb04178..a68f4a718 100644
@@ -132,6 +132,7 @@ while( my $l = <DUMP> ) {
   next if $l =~ /^\;/;
   my $sigHR = linesignature($l);
+  next unless length($sigHR);
   my $sig = $sigHR;
Summary of changes:
 NEWS                              |  4 ++--
 postgis/common_before_upgrade.sql |  8 +++++++-
 postgis/postgis_after_upgrade.sql | 14 +++++++++++---
 utils/postgis_restore.pl.in       |  4 ++++
 4 files changed, 24 insertions(+), 6 deletions(-)
hooks/post-receive
