[postgis-tickets] [PostGIS] #5580: When encounting an empty geometry, potential bug in the ST_3DIntersects function
PostGIS trac at osgeo.org
Wed Oct 18 04:24:58 PDT 2023
function
 Reporter:  Wenjing  |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 3.4.1
Component:  postgis  |    Version:  3.4.x
 Keywords:           |
 Consider this query:
 SELECT
 ST_3DIntersects(a1, a2)
 FROM ST_GeomFromText('GEOMETRYCOLLECTION Z (POINT Z EMPTY, POINT Z (0 0
 0))') As a1
 , ST_GeomFromText('POINT Z (0 0 0)') As a2;
 --excepted{t}; actual{f}
 POINT Z (0 0 0) is the two geometries' intersection. So the excepted
 result of 3DIntersects is true.
 But the 3DIntersects function doesn't consider they intersect only when
 inserting an empty geometry before this point.
 Moreover, using the 2D Intersects function in this situation, we can get
 the expected result that they intersect.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5580>
