[postgis-tickets] [PostGIS] #5584: PostGIS Upgrade Issue
PostGIS trac at osgeo.org
Fri Oct 20 04:41:23 PDT 2023
  Reporter:  rama                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  critical               |  Milestone:  PostGIS Packaging
 Component:  build/upgrade/install  |    Version:  3.3.x
Resolution:                         |   Keywords:
Description changed by rama:
Old description:
> I am facing an issue with PostGIS Upgrade from 2.5.0 to 3.3.3. Please
> check and help me out to fix the issue.
> Environment Details
> Os: Windows Environment (Windows 2016)
> Postgresql Version: 11
> Postgis Upgrade from 2.5.0 to 3.3.3
> Download and installation done from stack builder
> Current Version of Database and Postgis
>   DATABASE_VERSION
>  PostgreSQL 11.0, compiled by Visual C++ build 1914, 64-bit
> (1 row)
> POSTGIS_VERSION
>  POSTGIS="2.5.0 r16836" [EXTENSION] PGSQL="110" GEOS="3.7.0-CAPI-1.11.0
> 3.7.0" SFCGAL="1.3.2" PROJ="Rel. 4.9.3, 15 August 2016" GDAL="GDAL 2.2.4,
> released 2018/03/19 GDAL_DATA not found" LIBXML="2.7.8" LIBJSON="0.12"
> LIBPROTOBUF="1.2.1" TOPOLOGY RASTER
> (1 row)
> Command Execution Details
> ALTER EXTENSION postgis UPDATE TO "3.3.3";
> SELECT postgis_extensions_upgrade();
> ERROR message:
> WARNING:  unpackaging raster
> WARNING:  PostGIS Raster functionality has been unpackaged
> HINT:  type `SELECT postgis_extensions_upgrade();` to finish the upgrade.
> After upgrading, if you want to drop raster, run: DROP EXTENSION
> postgis_raster;
> ERROR:  could not load library "R:/Database/11/lib/postgis-3.dll": The
> specified procedure could not be found.
> postgis_raster;
New description:
 Environment Details
   DATABASE_VERSION
 (1 row)
 POSTGIS_VERSION
 (1 row)
 ERROR message:
 postgis_raster;
 postgis_raster;
 CONTEXT:  SQL statement "ALTER EXTENSION postgis UPDATE TO "3.3.3";"
 PL/pgSQL function postgis_extensions_upgrade() line 22 at EXECUTE
 SQL state: XX000
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5584#comment:7>
