[postgis-tickets] [PostGIS] #5584: PostGIS Upgrade Issue
PostGIS trac at osgeo.org
Fri Oct 20 05:06:23 PDT 2023
  Reporter:  rama                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  critical               |  Milestone:  PostGIS Packaging
 Component:  build/upgrade/install  |    Version:  3.3.x
Resolution:                         |   Keywords:
Comment (by strk):
 Do you have access to the database system ?
 There should be a file called postgis--2.5.0--3.3.3.sql in the postgresql
 extensions directory containing all the statement taking you from 2.5.0 to
 3.3.3, including the `RAISE WARNING` lines you seem to be able to see.
 What you could do is add more `RAISE WARNING` to spot the exact place in
 which the failure occurs.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5584#comment:8>
