[postgis-tickets] [PostGIS] #5586: Crash bug when using ST_Intersects
PostGIS trac at osgeo.org
Tue Oct 24 18:36:51 PDT 2023
  Reporter:  Wenjing   |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  critical  |  Milestone:  PostGIS 3.4.1
 Component:  postgis   |    Version:  3.4.x
Resolution:            |   Keywords:
Comment (by Wenjing):
 It is from https://registry.hub.docker.com/r/postgis/postgis/.
 POSTGIS="3.4.0 0874ea3" [EXTENSION] PGSQL="150" GEOS="3.9.0-CAPI-1.16.2"
 SFCGAL="1.3.8" PROJ="7.2.1 NETWORK_ENABLED=OFF URL_ENDPOINT=
 https://cdn.proj.org
 USER_WRITABLE_DIRECTORY=/var/lib/postgresql/.local/share/proj
 DATABASE_PATH=/usr/share/proj/proj.db" LIBXML="2.9.
 10" LIBJSON="0.15" LIBPROTOBUF="1.3.3" WAGYU="0.5.0 (Internal)" TOPOLOGY
 PostgreSQL 15.4 (Debian 15.4-1.pgdg110+1) on x86_64-pc-linux-
 gnu, compiled by gcc (Debian 10.2.1-6) 10.2.1 20210110, 64-bit
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5586#comment:3>
