[postgis-tickets] [PostGIS] #5586: Crash bug when using ST_Intersects
PostGIS trac at osgeo.org
Wed Oct 25 03:46:24 PDT 2023
  Reporter:  Wenjing   |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  critical  |  Milestone:  PostGIS 3.4.1
 Component:  postgis   |    Version:  3.4.x
Resolution:            |   Keywords:
Comment (by Wenjing):
 I think you have solved this issue. =-)
 Because it cannot be triggered in the newest version:
 POSTGIS="3.5.0dev 3.4.0rc1-705-g5c3ec8392" [EXTENSION] PGSQL="170"
 GEOS="3.10.6dev-CAPI-1.16.3" PRO
 J="8.2.1 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
 USER_WRITABLE_DIRECTORY=/tmp/proj DAT
 ABASE_PATH=/usr/share/proj/proj.db" LIBXML="2.9.13" PostgreSQL 17devel on
 x86_64-pc-linux-gnu, compi
 led by gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, 64-bit
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5586#comment:4>
