[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-705-g5c3ec8392
Tue Oct 24 21:23:48 PDT 2023
the project "PostGIS".
       via  5c3ec839295a7541805a9b6f2ee0b081c559f4d9 (commit)
      from  6926524812f3f78bf570526539761f495aa4b9d2 (commit)
revisions in full, below.
commit 5c3ec839295a7541805a9b6f2ee0b081c559f4d9
Author: Wang Dapeng <wangdapeng20191008 at gmail.com>
Date:   Wed Oct 25 02:39:28 2023 +0000
    Translated PostGIS Manual using Weblate (Chinese (Simplified))
    Currently translated at 99.9% (5602 of 5605 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/zh_Hans/
diff --git a/doc/po/zh_Hans/postgis-manual.po b/doc/po/zh_Hans/postgis-manual.po
index 4763cb0cc..629766801 100644
--- a/doc/po/zh_Hans/postgis-manual.po
+++ b/doc/po/zh_Hans/postgis-manual.po
@@ -6,8 +6,8 @@ msgstr ""
 "Project-Id-Version: postgis 3.5\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2023-10-06 06:13+0000\n"
-"PO-Revision-Date: 2023-10-20 09:23+0000\n"
-"Last-Translator: Zuochenwei <zuochenwei5 at gmail.com>\n"
+"PO-Revision-Date: 2023-10-25 04:23+0000\n"
+"Last-Translator: Wang Dapeng <wangdapeng20191008 at gmail.com>\n"
 "Language-Team: Chinese (Simplified) <https://weblate.osgeo.org/projects/"
 "postgis/postgis-manual/zh_Hans/>\n"
 "Language: zh_Hans\n"
@@ -3909,8 +3909,8 @@ msgid ""
 "TopoGeometry are the properties: topology_id, layer_id, id integer, type "
 "integer."
 msgstr ""
-"复合类型是指特定拓扑层中的拓扑几何结构,具有特定类型和特定id。 TopoGeometry "
-"的元素是属性:topology_id、layer_id、id 整数、type 整数。"
+"一个复合类型,它引用了特定拓扑层中的拓扑几何图形,具有特定的类型和特定的标识"
+"符。TopoGeometry 的元素包括属性:topology_id、layer_id、id 整数和 type 整数。"
 #. Tag: para
 #, no-c-format
@@ -3953,14 +3953,14 @@ msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Casting Behavior"
-msgstr "强制转换行为"
+msgstr "类型强制转换"
 #. Tag: para
 #, no-c-format
 msgid ""
 "This section lists the automatic as well as explicit casts allowed for this "
 "data type"
-msgstr "本节列出了此数据类型允许的显式和自动强制转换"
+msgstr "这个部分列出了允许用于这种数据类型的自动转换以及显式转换"
 #. Tag: entry
 #, no-c-format
@@ -3975,7 +3975,7 @@ msgstr "行为"
 #. Tag: entry
 #, no-c-format
 msgid "geometry"
-msgstr "几何"
+msgstr "geometry"
 #. Tag: entry
 #, no-c-format
@@ -6733,16 +6733,16 @@ msgstr ""
 "元素)的拓扑 element_id、element_type。"
 #. Tag: para
-#, no-c-format
+#, fuzzy, no-c-format
 msgid ""
 "Returns a set of element_id,element_type (topoelements) corresponding to "
 "primitive topology elements <xref linkend=\"topoelement\"/> (1: nodes, 2: "
 "edges, 3: faces) that a given topogeometry object in <varname>toponame</"
 "varname> schema is composed of."
 msgstr ""
-"返回与<varname>拓扑名称</varname>架构中给定拓扑几何对象组成的原始拓扑元素 "
-"<xref linkend=\"topoelement\"/>(1:节点,2:边,3:面)对应的一组 "
-"element_id、element_type(topoelements)。"
+"返回一组element_id和element_type(topoelements),对应于指定的位于 "
+"<varname>toponame</varname> 模式中的拓扑几何对象所由之原始拓扑元素 <xref "
+"linkend=\"topoelement\"/>(1:节点,2:边,3:面)。"
 #. Tag: para
 #, no-c-format
@@ -7078,12 +7078,12 @@ msgstr ""
 "过图层并单独处理这些图层。"
 #. Tag: para
-#, no-c-format
 msgid ""
 "Invoking <filename>pgtopo_export</filename> with the <code>--help</code> (or "
 "<code>-h</code> for short) switch will always print short usage string."
 msgstr ""
-"使用<code> --help </code>(或简称 <code>-h</code>)命令调用 "
+"使用<code>--help </code>(或简称 <code>-h</code>)命令调用 "
 "<filename>pgtopo_export</filename> 将始终打印简短的用法字符串。"
 #. Tag: para
@@ -11970,17 +11970,16 @@ msgid "Tests if a LineString is closed and simple."
 msgstr "检测线串是闭合的还是简单的。"
 #. Tag: para
-#, no-c-format
 msgid ""
 "Returns <varname>TRUE</varname> if this <varname>LINESTRING</varname> is "
 "both <xref linkend=\"ST_IsClosed\"/> (<code>ST_StartPoint(g) ~= "
 "ST_Endpoint(g)</code>) and <xref linkend=\"ST_IsSimple\"/> (does not self "
 "intersect)."
 msgstr ""
-"如果这个<varname>线串</varname>(LINESTRING)既是封闭的(即 <xref linkend="
-"\"ST_IsClosed\"/> 返回真,即 <code>ST_StartPoint(g) ~= ST_Endpoint(g)</"
-"code>),又是简单的(即没有自交,即 <xref linkend=\"ST_IsSimple\"/> 返回"
-"真),则返回 <varname>TRUE</varname>。"
+"如果这个 <varname>LINESTRING</varname> 既是 <xref linkend=\"ST_IsClosed\""
+"/>(<code>ST_StartPoint(g) ~= ST_Endpoin(g)</code>)又是 <xref linkend="
+"\"ST_IsSimple\"/>(不自交),则返回 <varname>TRUE</varname>。"
 #. Tag: para
 #, no-c-format
@@ -17954,7 +17953,7 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid "Availability: 1.5, requires libxml2 2.6+"
-msgstr "可用性: 1.5需要 libxml2 2.6 或更高版本。"
+msgstr "可用性:1.5,需要 libxml2 2.6+"
 #. Tag: para
 #, no-c-format
Summary of changes:
 doc/po/zh_Hans/postgis-manual.po | 37 ++++++++++++++++++-------------------
 1 file changed, 18 insertions(+), 19 deletions(-)
hooks/post-receive
