[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-706-g93bdd3bff
Tue Oct 24 21:50:04 PDT 2023
the project "PostGIS".
       via  93bdd3bffe07971e5e71449bfdd9103b51e25940 (commit)
      from  5c3ec839295a7541805a9b6f2ee0b081c559f4d9 (commit)
revisions in full, below.
commit 93bdd3bffe07971e5e71449bfdd9103b51e25940
Author: Regina Obe <lr at pcorp.us>
Date:   Wed Oct 25 00:48:39 2023 -0400
    ST_Contour improved docs
     - Add description for each input arg
     References #5585 for postgis 3.5.0
diff --git a/doc/reference_raster.xml b/doc/reference_raster.xml
index 2788617e0..a18578f6d 100644
--- a/doc/reference_raster.xml
+++ b/doc/reference_raster.xml
@@ -1356,6 +1356,33 @@ WHERE short_name = 'GTiff') As g;
             When the <varname>fixed_levels</varname> parameter is a non-empty
             array, the <varname>level_interval</varname> and <varname>level_base</varname> parameters are ignored.
         </para>
+        <para>
+            Input parameters are:
+        </para>
+        <variablelist>
+            <varlistentry><term><varname>rast</varname></term>
+                <listitem><para>The raster to generate the contour of</para></listitem>
+            </varlistentry>
+            <varlistentry><term><varname>bandnumber</varname></term>
+                <listitem><para>The band to generate the contour of</para></listitem>
+            </varlistentry>
+            <varlistentry><term><varname>level_interval</varname></term>
+                <listitem><para>The elevation interval between contours generated</para></listitem>
+            </varlistentry>
+            <varlistentry><term><varname>level_base</varname></term>
+                <listitem><para>The "base" relative to which contour intervals are applied,
+                this is normally zero, but could be different.
+                To generate 10m contours at 5, 15, 25, ... the LEVEL_BASE would be 5.</para></listitem>
+            </varlistentry>
+            <varlistentry><term><varname>fixed_levels</varname></term>
+            </varlistentry>
+            <varlistentry><term><varname>polygonize</varname></term>
+                <listitem><para>If <literal>true</literal>, contour polygons will be created, rather than polygon lines.</para></listitem>
+            </varlistentry>
+        </variablelist>
         <para>
             Return values are a set of records with the following attributes:
         </para>
Summary of changes:
 doc/reference_raster.xml | 27 +++++++++++++++++++++++++++
 1 file changed, 27 insertions(+)
hooks/post-receive
