[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-707-g83555929f
Tue Oct 24 21:58:10 PDT 2023
the project "PostGIS".
       via  83555929fd398344c4a411db69427d41f80a7012 (commit)
      from  93bdd3bffe07971e5e71449bfdd9103b51e25940 (commit)
revisions in full, below.
commit 83555929fd398344c4a411db69427d41f80a7012
Author: Regina Obe <lr at pcorp.us>
Date:   Wed Oct 25 00:58:07 2023 -0400
    Add default args labels  for ST_Contour
diff --git a/doc/reference_raster.xml b/doc/reference_raster.xml
index a18578f6d..8216d600a 100644
--- a/doc/reference_raster.xml
+++ b/doc/reference_raster.xml
@@ -1337,11 +1337,11 @@ WHERE short_name = 'GTiff') As g;
           <funcprototype>
             <funcdef>setof record <function>ST_Contour</function></funcdef>
             <paramdef><type>raster </type><parameter>rast</parameter></paramdef>
-            <paramdef><type>integer </type><parameter>bandnumber</parameter></paramdef>
-            <paramdef><type>double precision </type><parameter>level_interval</parameter></paramdef>
-            <paramdef><type>double precision </type><parameter>level_base</parameter></paramdef>
-            <paramdef><type>double precision[] </type><parameter>fixed_levels</parameter></paramdef>
-            <paramdef><type>boolean </type><parameter>polygonize</parameter></paramdef>
+            <paramdef choice="opt"><type>integer </type><parameter>bandnumber=1</parameter></paramdef>
+            <paramdef choice="opt"><type>double precision </type><parameter>level_interval=100.0</parameter></paramdef>
+            <paramdef choice="opt"><type>double precision </type><parameter>level_base=0.0</parameter></paramdef>
+            <paramdef choice="opt"><type>double precision[] </type><parameter>fixed_levels=ARRAY[]</parameter></paramdef>
+            <paramdef choice="opt"><type>boolean </type><parameter>polygonize=false</parameter></paramdef>
           </funcprototype>
         </funcsynopsis>
       </refsynopsisdiv>
Summary of changes:
 doc/reference_raster.xml | 10 +++++-----
 1 file changed, 5 insertions(+), 5 deletions(-)
hooks/post-receive
