[PostGIS] #5591: Upgrading to 3.3.5dev: ERROR: extension "postgis" has no update path from version "3.3.5dev" to version "ANY"
PostGIS trac at osgeo.org
Fri Oct 27 00:50:06 PDT 2023
 Reporter:  strk     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 3.3.5
Component:  postgis  |    Version:  3.3.x
 Keywords:           |
 After backporting run_test.pl to the stable-3.3 branch we got these
 failures:
 Upgrading PostGIS in 'postgis_reg-3.3' using: ALTER EXTENSION postgis
 UPDATE TO 'ANY'; ALTER EXTENSION postgis UPDATE TO '3.3.5dev'
 version "ANY"
 See https://woodie.osgeo.org/repos/30/pipeline/1379/6#L3915
 I guess run_test.pl is just assuming too much about the target database
 upgrade mechanism (ANY was introduced in 3.4?)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5591>
