[PostGIS] #5591: Upgrading to 3.3.5dev: ERROR: extension "postgis" has no update path from version "3.3.5dev" to version "ANY"
PostGIS trac at osgeo.org
Fri Oct 27 00:52:00 PDT 2023
  Reporter:  strk     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.3.5
 Component:  postgis  |    Version:  3.3.x
Resolution:           |   Keywords:
Comment (by strk):
 I confirm commit [fb96c51744307232166e48d600b6ca9e1fbb7900/git] changed
 the run_test.pl in stable-3.3 from using the "next" suffix to using "ANY".
 I guess we want to use either one or the other based on target version.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5591#comment:1>
