[SCM] PostGIS branch master updated. 3.4.0rc1-722-gf6a7ce541
Mon Oct 30 11:03:25 PDT 2023
the project "PostGIS".
       via  f6a7ce541d1badaa46f9d3785d52680cab572db9 (commit)
       via  cac91cf88e1315477ac1964b2e810208dea56dfe (commit)
      from  a6aec22a64d7bcad2ac76cac3e68fd7579db2a36 (commit)
revisions in full, below.
commit f6a7ce541d1badaa46f9d3785d52680cab572db9
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Oct 30 19:02:54 2023 +0100
    Update PostGIS Manual translation template
diff --git a/doc/po/templates/postgis-manual.pot b/doc/po/templates/postgis-manual.pot
index 3418a21ce..5ddb31ef2 100644
--- a/doc/po/templates/postgis-manual.pot
+++ b/doc/po/templates/postgis-manual.pot
@@ -6,7 +6,7 @@ msgid ""
 msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
-"POT-Creation-Date: 2023-10-06 06:13+0000\n"
+"POT-Creation-Date: 2023-10-30 18:01+0000\n"
 "PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
 "Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
 "Language-Team: LANGUAGE <kde-i18n-doc at kde.org>\n"
@@ -7989,6 +7989,11 @@ msgstr ""
 msgid "Han Wang"
 msgstr ""
+#. Tag: member
+#, no-c-format
+msgid "Hans Lemuet"
+msgstr ""
 #. Tag: member
 #, no-c-format
 msgid "Haribabu Kommi"
@@ -18801,17 +18806,37 @@ msgstr ""
 #. Tag: refpurpose
 #, no-c-format
-msgid "Return a geometry as a GeoJSON element."
+msgid "Return a geometry or feature in GeoJSON format."
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"Returns a geometry as a GeoJSON \"geometry\", or a row as a GeoJSON "
-"\"feature\". (See the <link xlink:href=\"https://tools.ietf.org/html/"
-"rfc7946\">GeoJSON specifications RFC 7946</link>). 2D and 3D Geometries are "
-"both supported. GeoJSON only support SFS 1.1 geometry types (no curve "
-"support for example)."
+"Returns a geometry as a GeoJSON \"geometry\" object, or a row as a GeoJSON "
+"\"feature\" object."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The resulting GeoJSON geometry and feature representations conform with the "
+"<link xlink:href=\"https://tools.ietf.org/html/rfc7946\">GeoJSON "
+"specifications RFC 7946</link>, except when the parsed geometries are "
+"referenced with a CRS other than WGS84 longitude and latitude (<link xlink:"
+"href=\"https://epsg.io/4326\">EPSG:4326</link>, <link xlink:href=\"http://"
+"epsg.io/4326.gml\">urn:ogc:def:crs:OGC::CRS84</link>); the GeoJSON geometry "
+"object will then have a short CRS SRID identifier attached by default. 2D "
+"and 3D Geometries are both supported. GeoJSON only supports SFS 1.1 geometry "
+"types (no curve support for example)."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The <varname>geom_column</varname> parameter is used to distinguish between "
+"multiple geometry columns. If omitted, the first geometry column in the "
+"record will be determined. Conversely, passing the parameter will save "
+"column type lookups."
 msgstr ""
 #. Tag: para
@@ -23124,6 +23149,41 @@ msgid ""
 "parameters are ignored."
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Input parameters are:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "The raster to generate the contour of"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "The band to generate the contour of"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "The elevation interval between contours generated"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The \"base\" relative to which contour intervals are applied, this is "
+"normally zero, but could be different. To generate 10m contours at 5, 15, "
+"25, ... the LEVEL_BASE would be 5."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"If <literal>true</literal>, contour polygons will be created, rather than "
+"polygon lines."
+msgstr ""
 #. Tag: para
 #, no-c-format
 msgid "Return values are a set of records with the following attributes:"
@@ -23169,11 +23229,6 @@ msgid ""
 "gdal_grid_tut.html\">GDAL grid tutorial</link>."
 msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Input parameters are:"
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -32066,7 +32121,7 @@ msgstr ""
 #, no-c-format
 msgid ""
 "Returns the smallest measure at which points interpolated along the given "
-"trajectories are at the smallest distance."
+"trajectories are the least distance apart."
 msgstr ""
 #. Tag: para
@@ -32080,8 +32135,8 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"See <xref linkend=\"ST_LocateAlong\"/> for getting the actual points at the "
-"given measure."
+"To obtain the actual points at the computed measure use <xref "
+"linkend=\"ST_LocateAlong\"/> ."
 msgstr ""
 #. Tag: para
@@ -32101,7 +32156,8 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"Returns the minimum distance two moving objects have ever been each other."
+"Returns the distance (in 2D) between two trajectories at their closest point "
+"of approach."
 msgstr ""
 #. Tag: para
commit cac91cf88e1315477ac1964b2e810208dea56dfe
Date:   Mon Oct 30 18:59:33 2023 +0100
    Update ST_AsGeoJSON docs - patch by Andre Siefken
    Closes #4764
diff --git a/doc/reference_output.xml b/doc/reference_output.xml
index fa8e28b94..428a85742 100644
--- a/doc/reference_output.xml
+++ b/doc/reference_output.xml
@@ -612,7 +612,7 @@ F000000000000000000000000000000000000000000000000');
 	  <refnamediv>
 		<refname>ST_AsGeoJSON</refname>
-		<refpurpose>Return a geometry as a GeoJSON element.</refpurpose>
+		<refpurpose>Return a geometry or feature in GeoJSON format.</refpurpose>
 	  </refnamediv>
 	  <refsynopsisdiv>
@@ -620,7 +620,7 @@ F000000000000000000000000000000000000000000000000');
 			<funcprototype>
 				<funcdef>text <function>ST_AsGeoJSON</function></funcdef>
 				<paramdef><type>record </type> <parameter>feature</parameter></paramdef>
-				<paramdef choice="opt"><type>text </type> <parameter>geomcolumnname</parameter></paramdef>
+				<paramdef choice="opt"><type>text </type> <parameter>geom_column=""</parameter></paramdef>
 				<paramdef choice="opt"><type>integer </type> <parameter>maxdecimaldigits=9</parameter></paramdef>
 				<paramdef choice="opt"><type>boolean </type> <parameter>pretty_bool=false</parameter></paramdef>
 			</funcprototype>
@@ -642,10 +642,32 @@ F000000000000000000000000000000000000000000000000');
 	  <refsection>
 		<title>Description</title>
-		  <para>Returns a geometry as a GeoJSON "geometry", or a row as a GeoJSON "feature".
-          (See the <link xlink:href="https://tools.ietf.org/html/rfc7946">GeoJSON specifications RFC 7946</link>).
- 2D and 3D Geometries are both supported.
- GeoJSON only support SFS 1.1 geometry types (no curve support for example).</para>
+        <para>
+Returns a geometry as a GeoJSON "geometry" object,
+or a row as a GeoJSON "feature" object.
+        </para>
+        <para>
+The resulting GeoJSON geometry and feature representations conform
+with the <link xlink:href="https://tools.ietf.org/html/rfc7946">GeoJSON
+specifications RFC 7946</link>, except when the parsed geometries
+are referenced with a CRS other than WGS84 longitude and latitude
+(<link xlink:href="https://epsg.io/4326">EPSG:4326</link>, <link
+xlink:href="http://epsg.io/4326.gml">urn:ogc:def:crs:OGC::CRS84</link>);
+the GeoJSON geometry object will then have a short CRS SRID identifier
+attached by default.
+2D and 3D Geometries are both supported.
+GeoJSON only supports SFS 1.1 geometry types
+(no curve support for example).
+        </para>
+        <para>
+The <varname>geom_column</varname> parameter is used to distinguish
+between multiple geometry columns.
+If omitted, the first geometry column in the record will be determined.
+Conversely, passing the parameter will save column type lookups.
+</para>
 			<para>The <varname>maxdecimaldigits</varname> argument may be used to reduce the maximum number of decimal places used in output (defaults to 9). If you are using EPSG:4326 and are outputting the geometry only for display, <varname>maxdecimaldigits</varname>=6 can be a good choice for many maps.</para>
Summary of changes:
 doc/po/templates/postgis-manual.pot | 88 ++++++++++++++++++++++++++++++-------
 doc/reference_output.xml            | 34 +++++++++++---
 2 files changed, 100 insertions(+), 22 deletions(-)
hooks/post-receive
