[postgis-tickets] [PostGIS] #5524: ERROR: cannot drop function st_askml(integer, geometry, integer, text) because extension postgis requires it
PostGIS trac at osgeo.org
Fri Sep 1 05:41:34 PDT 2023
#5524: ERROR:  cannot drop function st_askml(integer,geometry,integer,text)
 Reporter:  strk                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  medium                 |  Milestone:  PostGIS 3.4.1
Component:  build/upgrade/install  |    Version:  3.4.x
 Keywords:                         |
 spotted running:
 > regress/run_test.pl -v —extension —upgrade-path=2.5.7—3.5.0dev
 regress/core/legacy
 The problem is that the function is not deprecated on postgis upgrade.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5524>
