[postgis-tickets] [PostGIS] #5524: ERROR: cannot drop function st_askml(integer, geometry, integer, text) because extension postgis requires it
PostGIS trac at osgeo.org
Fri Sep 1 06:22:01 PDT 2023
#5524: ERROR:  cannot drop function st_askml(integer,geometry,integer,text)
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.4.1
 Component:  build/upgrade/install  |    Version:  3.4.x
Resolution:                         |   Keywords:
Comment (by Sandro Santilli <strk@…>):
 In [changeset:"36bc628269f2324f8fae82b588466b8633b8fd63/git"
 36bc6282/git]:
 {{{#!CommitTicketReference repository="git"
 revision="36bc628269f2324f8fae82b588466b8633b8fd63"
 Drop ST_AsKML(int,geometry,int,text) sig deprecated in 3.0
 References #5524 in master (3.5.0dev) branch
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5524#comment:1>
