[postgis-tickets] [PostGIS] #5524: ERROR: cannot drop function st_askml(integer, geometry, integer, text) because extension postgis requires it
PostGIS trac at osgeo.org
Tue Sep 5 02:41:06 PDT 2023
#5524: ERROR:  cannot drop function st_askml(integer,geometry,integer,text)
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 3.4.1
 Component:  build/upgrade/install  |    Version:  3.4.x
Resolution:  fixed                  |   Keywords:
Changes (by strk):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 Closed by [e428b70577bd51d3924346d9f0124a6d37ef4ff8/git] in 3.4 branch
 (3.4.1dev)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5524#comment:2>
