[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-189-g5599ab151
Mon Sep 4 00:37:46 PDT 2023
the project "PostGIS".
       via  5599ab1518b1d406fa82e74d769f0c4916b53aeb (commit)
       via  950b535067df26cc4f9f0ae063f3d317900e5072 (commit)
      from  9bc023904ddbcbe0209879db41c03f0e9c3ba70c (commit)
revisions in full, below.
commit 5599ab1518b1d406fa82e74d769f0c4916b53aeb
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Sep 1 23:13:43 2023 +0200
    Fix topology locked upgrade
diff --git a/topology/Makefile.in b/topology/Makefile.in
index fcaabf656..23080ba31 100644
--- a/topology/Makefile.in
+++ b/topology/Makefile.in
@@ -118,7 +118,7 @@ topology_upgrade.sql.in:  topology.sql ../utils/create_upgrade.pl
 	$(PERL) @top_srcdir@/utils/create_upgrade.pl $< > $@
 	#$(PERL) -0777 -ne 's/^(CREATE|ALTER) (CAST|OPERATOR|TYPE|TABLE|SCHEMA|DOMAIN|TRIGGER).*?;//msg;print;' $< > $@
-topology_upgrade.sql: topology_before_upgrade.sql topology_upgrade.sql.in topology_after_upgrade.sql
+topology_upgrade.sql: ../postgis/common_before_upgrade.sql topology_before_upgrade.sql topology_upgrade.sql.in topology_after_upgrade.sql ../postgis/common_after_upgrade.sql
 	echo "BEGIN;" > $@
 	cat $^ > $@
 	echo "COMMIT;" >> $@
diff --git a/topology/topology.sql.in b/topology/topology.sql.in
index ef89fdaeb..b1d5969dd 100644
--- a/topology/topology.sql.in
+++ b/topology/topology.sql.in
@@ -659,7 +659,6 @@ LANGUAGE 'plpgsql' VOLATILE;
 -- hierarchical or primitive, but always assumes primitive.
-DROP FUNCTION IF EXISTS topology.populate_topology_layer();
 CREATE OR REPLACE FUNCTION topology.populate_topology_layer()
 	RETURNS TABLE(schema_name text, table_name text, feature_column text)
 AS
diff --git a/topology/topology_before_upgrade.sql.in b/topology/topology_before_upgrade.sql.in
index 03e93c6fe..aa0c7252f 100644
--- a/topology/topology_before_upgrade.sql.in
+++ b/topology/topology_before_upgrade.sql.in
@@ -7,24 +7,40 @@
 -- These are functions where the argument names may have changed  --
 -- so have to be dropped before upgrade can happen for 9.0+ --
 -- argument names changed --
 -- we might want to take toTopoGeom one out before release since
 -- I don't think too many people installed the bad name
-DROP FUNCTION IF EXISTS topology.toTopoGeom(Geometry, varchar, int, float8);
+SELECT NULL FROM _postgis_drop_function_by_signature('
+topology.toTopoGeom(Geometry, varchar, int, float8)
 -- used to be in public, will now be moved to topology
-DROP FUNCTION IF EXISTS postgis_topology_scripts_installed();
+public.postgis_topology_scripts_installed()
 -- Removed in 2.2.0 when topology API moved to liblwgeom
-DROP FUNCTION IF EXISTS topology._ST_RemEdgeCheck(varchar, integer, integer, integer, integer);
-DROP FUNCTION IF EXISTS topology._ST_AddFaceSplit(varchar, integer, integer, boolean);
+topology._ST_RemEdgeCheck(varchar, integer, integer, integer, integer)
+', '2.2.0');
+-- Removed in 2.2.0 when topology API moved to liblwgeom
+topology._ST_AddFaceSplit(varchar, integer, integer, boolean)
+', '2.2.0');
 -- Added optional bbox parameter in 3.2.0
-DROP FUNCTION IF EXISTS topology.validatetopology(varchar);
+topology.validatetopology(varchar)
+', '3.2.0');
 -- Merged the two function into one with both allowEdgeSplitting and setContainingFace parameters
 -- being optional (3.2.0)
-DROP FUNCTION IF EXISTS topology.AddNode(varchar, geometry);
-DROP FUNCTION IF EXISTS topology.AddNode(varchar, geometry, boolean, boolean);
+topology.AddNode(varchar, geometry)
+', '3.2.0');
+topology.AddNode(varchar, geometry, boolean, boolean)
+', '3.2.0');
commit 950b535067df26cc4f9f0ae063f3d317900e5072
Date:   Fri Sep 1 22:10:27 2023 +0200
    Lock all non-catalog functions for locked upgrade, not just st_ prefixed
diff --git a/regress/hooks/use-all-functions.sql b/regress/hooks/use-all-functions.sql
index 9100e2e2a..475a09e23 100644
--- a/regress/hooks/use-all-functions.sql
+++ b/regress/hooks/use-all-functions.sql
@@ -26,10 +26,8 @@ BEGIN
 			) f
 		FROM pg_catalog.pg_proc
 		WHERE
-		-- We use the ST_ prefix as a sign that this function
-		-- belongs to PostGIS and is meant for public usage,
-		-- but the condition could be improved
-		proname like 'st\_%'
+		pronamespace::regnamespace::text !~ '^pg_'
+		AND pronamespace::regnamespace::text <> 'information_schema'
 		-- We only consider normal and window functions
 		-- ( not aggregates or procedures )
 		AND prokind in ('f','w')
@@ -42,6 +40,8 @@ BEGIN
 		AND proname NOT IN ( 'st_asmvt', 'st_fromflatgeobuf' )
 		-- Skip functions using VARIADIC or OUTPUT arguments
 		AND ( NOT coalesce(proargmodes, '{}') && ARRAY['v'::"char",'o'] )
+		-- Skip function having arguments of internal types
+		AND ( NOT proargtypes::oid[] && ARRAY ['internal'::regtype::oid] )
 	LOOP
 		EXECUTE format(
 			'CREATE VIEW postgis_upgrade_test_data.locking_view AS SELECT %s',
Summary of changes:
 regress/hooks/use-all-functions.sql     |  8 ++++----
 topology/Makefile.in                    |  2 +-
 topology/topology.sql.in                |  1 -
 topology/topology_before_upgrade.sql.in | 30 +++++++++++++++++++++++-------
 4 files changed, 28 insertions(+), 13 deletions(-)
hooks/post-receive
