[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-190-g8c04f6000
Mon Sep 4 01:15:25 PDT 2023
the project "PostGIS".
       via  8c04f600036a17d8759b16ac5ba4bc1e1f3f6337 (commit)
      from  5599ab1518b1d406fa82e74d769f0c4916b53aeb (commit)
revisions in full, below.
commit 8c04f600036a17d8759b16ac5ba4bc1e1f3f6337
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Sep 4 10:14:27 2023 +0200
    Generalize skip list for locking functions
diff --git a/regress/hooks/use-all-functions.sql b/regress/hooks/use-all-functions.sql
index 475a09e23..62d0405ea 100644
--- a/regress/hooks/use-all-functions.sql
+++ b/regress/hooks/use-all-functions.sql
@@ -35,13 +35,13 @@ BEGIN
 		AND proname NOT IN (
 			'st_approxquantile' -- https://trac.osgeo.org/postgis/ticket/5498
-		-- Skip functions taking polymorphic arguments (anyelement)
-		-- as those ones would need us to cast to some real type.
-		AND proname NOT IN ( 'st_asmvt', 'st_fromflatgeobuf' )
 		-- Skip functions using VARIADIC or OUTPUT arguments
-		AND ( NOT coalesce(proargmodes, '{}') && ARRAY['v'::"char",'o'] )
+		AND ( NOT coalesce(proargmodes, '{}') && ARRAY['v', 'o']::"char"[] )
 		-- Skip function having arguments of internal types
-		AND ( NOT proargtypes::oid[] && ARRAY ['internal'::regtype::oid] )
+		AND ( NOT proargtypes::oid[] && ARRAY ['internal'::regtype]::oid[] )
+		-- Skip function having anyelement return type, to avoid:
+		-- ERROR:  function returning record called in context that cannot accept type record
+		AND ( NOT prorettype = ANY( ARRAY ['anyelement'::regtype] ) )
 	LOOP
 		EXECUTE format(
 			'CREATE VIEW postgis_upgrade_test_data.locking_view AS SELECT %s',
Summary of changes:
 regress/hooks/use-all-functions.sql | 10 +++++-----
 1 file changed, 5 insertions(+), 5 deletions(-)
hooks/post-receive
