[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-210-g175e57daa
Mon Sep 4 16:20:03 PDT 2023
the project "PostGIS".
       via  175e57daa7f5d21565f5b22f833ee58edc5be9c1 (commit)
      from  8f1892adcafe7e1bfe50c025779fe6975ad05d6b (commit)
revisions in full, below.
commit 175e57daa7f5d21565f5b22f833ee58edc5be9c1
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Sep 4 19:19:58 2023 -0400
    Fix xml entities on zh_Hans translations
diff --git a/doc/po/zh_Hans/installation.xml.po b/doc/po/zh_Hans/installation.xml.po
index 2c939f94c..99af494ab 100644
--- a/doc/po/zh_Hans/installation.xml.po
+++ b/doc/po/zh_Hans/installation.xml.po
@@ -111,7 +111,7 @@ msgid ""
 "Earlier versions of PostgreSQL are <emphasis>not</emphasis> supported."
 msgstr ""
 "PostGIS 模块是PostgreSQL后端服务器的扩展。 "
-"PostGIS&last_release_version<emphasis>需要</emphasis>完整的 PostgreSQL "
+"PostGIS &last_release_version;<emphasis>需要</emphasis>完整的 PostgreSQL "
 "服务器标头进行编译。你可以在PostgreSQL&min_postgres_version; - "
 "&max_postgres_version;之间构建。 "
 "<emphasis>不</emphasis>支持旧版本的PostgreSQL。"
@@ -597,7 +597,7 @@ msgstr "在没有栅格功能的情况下进行编译。"
 msgid ""
 "Disable topology support. There is no corresponding library as all logic "
 "needed for topology is in postgis-&last_release_version; library."
-msgstr "在没有拓扑支持的情况下进行编译。 拓扑所需的所有逻辑都是在postgis-&last_release_version库中创建的,因此没有关联的库。"
+msgstr "在没有拓扑支持的情况下进行编译。 拓扑所需的所有逻辑都是在postgis-&last_release_version; 库中创建的,因此没有关联的库。"
 #. Tag: para
 #: installation.xml:503
diff --git a/doc/po/zh_Hans/postgis.xml.po b/doc/po/zh_Hans/postgis.xml.po
index 7693c4519..3405654e3 100644
--- a/doc/po/zh_Hans/postgis.xml.po
+++ b/doc/po/zh_Hans/postgis.xml.po
@@ -65,7 +65,7 @@ msgstr ""
 #: postgis.xml:127
 #, no-c-format
 msgid "This is the manual for version &last_release_version;"
-msgstr "本手册的版本是&last_release_version;"
+msgstr "本手册的版本是 &last_release_version;"
 #. Tag: para
 #: postgis.xml:128
Summary of changes:
 doc/po/zh_Hans/installation.xml.po | 4 ++--
 doc/po/zh_Hans/postgis.xml.po      | 2 +-
 2 files changed, 3 insertions(+), 3 deletions(-)
hooks/post-receive
