[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-310-ge1a0f15ef
Wed Sep 6 08:25:43 PDT 2023
the project "PostGIS".
       via  e1a0f15ef7136a85c0ec05aaac4ea2af14761830 (commit)
      from  d3f7885d82baf21bf7041ce4b1c58f07beba55cd (commit)
revisions in full, below.
commit e1a0f15ef7136a85c0ec05aaac4ea2af14761830
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Sep 6 12:39:54 2023 +0200
    [woodie] enable build of Chinese translation
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs.yml
index 8b8dfd0ac..b1b91026f 100644
--- a/.woodpecker/docs.yml
+++ b/.woodpecker/docs.yml
@@ -115,6 +115,19 @@ steps:
           - "doc/po/fr/Makefile.in"
           - "doc/po/fr/*.po"
           - "utils/check_localized_cheatsheets.sh"
+  check-xml-zh_Hans:
+    image: *test_image
+    commands:
+      - make -C build-docs/doc/po/zh_Hans local-check-xml
+    group: localized-check-xml
+    when:
+      path:
+        include:
+          - <<: *common_doc_paths
+          # Localized assets
+          - "doc/po/zh_Hans/Makefile.in"
+          - "doc/po/zh_Hans/*.po"
+          - "utils/check_localized_cheatsheets.sh"
 ### TARGET html
   html-ja:
     image: *test_image
@@ -155,6 +168,19 @@ steps:
           - "doc/po/fr/*.po"
+  html-zh_Hans:
+    commands:
+      - make -C build-docs/doc/po/zh_Hans local-html
+    group: localized-html
+    when:
+      path:
+        include:
 ### TARGET cheatsheets
   cheatsheets-ja:
     image: *test_image
@@ -195,6 +221,19 @@ steps:
           - "doc/po/fr/*.po"
+  cheatsheets-zh_Hans:
+    commands:
+      - make -C build-docs/doc/po/zh_Hans local-cheatsheets
+    group: localized-cheatsheets
+    when:
+      path:
+        include:
 ### TARGET check-cheatsheets
   check-cheatsheets-ja:
     image: *test_image
@@ -235,6 +274,19 @@ steps:
           - "doc/po/fr/*.po"
+  check-cheatsheets-zh_Hans:
+    commands:
+      - make -C build-docs/doc/po/zh_Hans local-check-cheatsheets
+    group: localized-check-cheatsheets
+    when:
+      path:
+        include:
 ### TARGET pdf
   pdf-ja:
     image: *test_image
@@ -275,3 +327,16 @@ steps:
           - "doc/po/fr/*.po"
+  pdf-zh_Hans:
+    commands:
+      - make -C build-docs/doc/po/zh_Hans local-pdf
+    group: localized-pdf
+    when:
+      path:
+        include:
diff --git a/.woodpecker/update-docs-localized.sh b/.woodpecker/update-docs-localized.sh
index 131fbe067..3e2e33b34 100755
--- a/.woodpecker/update-docs-localized.sh
+++ b/.woodpecker/update-docs-localized.sh
@@ -3,7 +3,7 @@
 cd $(dirname $0)
 SUPPORTED_LANGUAGES=$(grep ^translations ../doc/Makefile.in | cut -d= -f2)
-SUPPORTED_LANGUAGES="ja de fr" # restrict built translations
+SUPPORTED_LANGUAGES="ja de fr zh_Hans" # restrict built translations
 TARGETS="check-xml html cheatsheets check-cheatsheets pdf"
Summary of changes:
 .woodpecker/docs.yml                 | 65 ++++++++++++++++++++++++++++++++++++
 .woodpecker/update-docs-localized.sh |  2 +-
 2 files changed, 66 insertions(+), 1 deletion(-)
hooks/post-receive
